Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
Speakers only playing on the right side. What to do? Sound is not balance!
Posted by amy_zmyou on
Anonymous
    New Friend:
  • 6 Answers
Mine also does this from time to time. I've had it for 4 or 5 years now so I think it's just a matter of wear and tear. I find that if I press down gently but firmly on both sides of the TOP of the iPod/iPhone, to firmly seat it, that will get the im600 back to stereo sound. This is easier to notice while you are playing the device with the volume turned up so you can hear it go into stereo mode.
Posted on Jan 23, 2011
Driver side speakers fade in and out
Sounds like you may have a short in the wiring to the speakers. You can play with the balance and fade controls to check the sound, but a professional car stereo installer can troubleshoot and replace that for you.
2answers
What would cause the driver side front door speaker and the passenger side rear deck speakers not to work. When if fade the sound all the way to the front with no sound in rear and with the balance turned...
Check the speakers if they work. Connect the speaker terminals using a short wire to a 1.5 volt battery (AA or any dry cell batter) and listen if there's a thumping sound when the wires are connected to the battery terminals. If there's no sound, your speakers are busted. If there's a sound, check if the wires are okay. Use the same method with the battery with the wires from the back of your stereo. Make a small cut on the wire and attach the short wires you used earlier.
I have the alpine cda-7894 in my 1994 mustang. I have the mach speaker upgrade. When I play my music the sound has no depth and sounds very flat with no bass, but if i change the balance to the right or...
You have a problem with the phasing of your speakers. This will happen if on or more of the speakers are installed incorrectly. To solve this, you must check the speakers and find which one of them does not have the positive and negative connected to where it should be. When connecting speakers it is crucial that the speakers (positive and negative terminals) are all connected to the corresponding (positive and negative) speaker outputs of your head unit. Now you can enjoy your sound again.
dreamsystems
Right side speaker is not working
Most likely, ensure the balance is set correctly to the middle.
If this is set correctly, try swapping the speakers. If the bad speaker (the right side one) fails to play when plugged into the left side cable, then the speaker is faulty. However if the bad speaker now plays but the good one doesn't, its an issue with either the cable or the sound card. Replace them in that order.
Hope this helps, Benji
I have a ford fiesta 2003 reg, when playing the
what type of cd it is? try to play another cd ,it could be problem with cd , cause if is problem with stereo system it should happen with radio.
1helpful
I've plugged in my speakers and the woofer but only the left speaker will play sound and its almost a whisper
Try to check for sound manager to check balance is on for both sides (left right) and wave balance is normal value. To call master volume just duble click system tray volume icon (next to clock) and check it.
No sound out of 4 of 5 speakers when using tv only.
switch around rca cords and verify its not a bad wire(s),Check and see in the TV menu audio settings are correct/ balances R/L etc. audio outputs are on,Try different theater amp if you have an extra.
2answers
My l/r channel will not work
With the radio on u will need to push audio button it will change to something different on the face push until speaker balance comes up & then push butons below it left or right to balance each side of speakers. For me it was the left speakers that i needed to balance good luck John
Speaker Balance Trouble
Can you reset this unit to default settings?
2answers
Mp3 player only plays on right side speakers
Have you tried a different jack? It could be faulty.
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
Top Altec Lansing Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
