It sounds like a mongoose got loose inside the washing machine and is being chased around by a barracuda between the drum and the inside canister. It makes a really loud banging noise and i cant even watch T.V. Now I opened up the top of the machine and I didn't see any sign of them in there. The springs were all set in there also.
The retaining nut/bolt for the drum has come loose. Remove the back cover and check the drum axle and attachments.
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.The noise seen on the front panle is due to vibration from the motor drive
For replacement of bearings check for tips on this visual link:
Thank You for using fixya
