The phone I purchased yesterday will not connect to the AC adaptor. I have tried unplugging, reinserting the cord, changing the batteries and reconnecting the phone line.
all your technicians require a fee, I believe I should not have to pay one. If I cannot get an answer I want a refund.
If your portable DVD player work with the AC power adapter in the wall outlet.100% the litium battery doesn't take any more holding charges.The litium battery should last u about 2 years with minium usages 2-3 hours a day.But that the DVD player and the litium battery must keep in very well conditon and wheather wise.Not in the heat or cold and the humitnity well shorten the lituim battey life very quickly and also could damages the portable DVD player too dosen't matter how much u used it.Tries webites like Amazon.com,Partstore.com,Ebay.com to buy a new litium battery or a compatible one.
Remove the Battery then clean the metal contacts on the Battery and in the battery compartment then press and hold the power button on the Computer for 30 seconds.
Next, reinsert the Battery and try to turn ON the Computer.
If the Computer keeps turning off then connect the AC adaptor to the Computer then try to turn it ON.
If the Computer keeps turning off automatically even when the AC adaptor is connected to it then the issue is with the power supply unit and requires to be replaced.
Please remove the Battery from the Battery bay and disconnect the AC Adaptor from the Notebook. Then, clean the metal contact in the Battery Bay and leave the Battery removed for half an hour. Next, connect the AC Adaptor to the Notebook and the power cable to a functional wall outlet and try to turn ON the Notebook. If the power LED on the Notebook doesn't glow then again disconnect the AC Adaptor and try removing and reinserting the RAM module. If the issue persists even after performing all the above steps then service will be required.
However, if the Notebook turns on after performing the above mentioned steps but the Battery is not detected then perform C: Drive Restore using the VAIO Recovery Center.
As per the specification published online, the Computer model VGN-N250E is preinstalled with the VAIO Recovery Center in the hidden partition of the Computer. You may use it to perform C: Drive Restore to restore the Computer to the original factory settings. Please make sure that the new Battery is installed in the Computer while performing the Complete System Restore.
Performing a C: Drive Recovery will erase all the data present in the C: Drive only and will reinstall the pre-installed Operating System, Applications and the original Drivers supplied with the Computer.
Please restart the Computer and keep on tapping the F10 key to access the VAIO Recovery Center. Next press the Enter key then select the "VAIO Recovery Center" option then follow the steps given in the link mentioned below to proceed with the C: Drive Restore.
try to remove the battery first and plug in the ac power adaptor and see if it works. if yes, then your battery is faulty.
if it doesn't work i suspected that there's a problem with the power socket from your machine. you can check it with the nearest service center near you.
Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
Confirm the system is not in HOLD mode Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
Confirm the backlight is ON Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
Confirm use of only licensed products (AC Adaptor, battery pack and charger) The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging: If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products. There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
Try the battery pack only Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
Try the battery pack in a different PSP system If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
Try a different PSP battery pack If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
Try the AC adaptor and the PSP battery pack Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
Try the AC adaptor / power cord only Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet. If the PSP system powers on, the battery may need to be replaced.
Check AC adaptor and power cord for damage Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
Check the electrical outlet Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
Try a different AC adaptor and power cord If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
Confirm no unauthorized system software or downloads were used Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
WLAN turned off Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
Power surge If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
Hve u tried a differnt adaptor , the adaptor might be blown too ,try replacing the adaptor , also check for the power cord if it has any kinks in it which may be interrupting the power supply , since the adaptor 18.5 v 3.5 a is the most common of all hp adaptors u should find one to try .
