Polaroid PhotoMax PDC 4055 Digital Camera Logo
Posted on Jan 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
THE PICTURES ARE BEING SAVE TO INTERNAL MEMORY NOT SD CARD AND CARD IS NOT LOCKED
Anonymous
Level 3:
  • Master 747 Answers
  • Posted on Jan 21, 2011
Anonymous
Master
Level 3:
Answers
747
Questions
0
Helped
177518
Points
2087
Okay the card is not locked I'm adding a diagram anyway. The next thing is did your format the memory card in the camera in which it is to be used? If you have just installed a new memory card it needs to be formatted. Or have you downloaded pictures from the memory card to the computer? Did you format the memory card in the computer? Did you unplug the camera or card reader without doing a safe disconnect? These are all reasons why you need to format the memory card.
Diagram just cause I have it on speed dial
Says memory card error and internal memory full. sometimes will recognize sd card but when picture is taken it either freezes camera or says no image/sound
It sounds like the camera is set to always save to the internal memory. With the SD card in place, adjust the settings to save to the SD card. (Sorry, I don't know the exact menu paths for your camera).
(If you have also copied your pictures off your camera, you can erase the internal memory and use that to take more pictures - however it will fill up again).
2answers
DC6550
We need to be sure of some things:
Are you saving the picture to the internal flash memory or an external SD card?
1) The internal memory will only hold 16MB of pictures, check if it's full.
2) The external SD memory can only be up to 1GB in size, anything bigger will not be recognized by the camera
1. Make sure the SD card is not "locked". Some SD cards have a little switch to prevent them to be written into.
2. SD card should be formatted by the camera preferably or as the FAT format in your PC.
Does this help you in any way?
Please give us more information as to how you are saving them and/or any further questions you may have.
Doesn't recognize memory card. I had an Eye Fi wireless memory card installed and now it's totally blank and the camera doesn't recognize it. Tried a regular SD memory card, and the camera doesn't...
Your camera is only supporting SD/MMC Cards (up to 2 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
IF IT COMES INTERNAL MEMORY FULL EVEN IF THE MEMORY CARD IS 2GB WHAT SHOULD WE DO
How to switch the camera over to saving pictures directly onto the SD card.
  1. Menu
  2. Cam settings
  3. Chose AUTO or SD card option and Press OK
1helpful
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • 2helpful
    How do i switch off internal memory
      1. Menu
      2. Cam settings
      After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • 2helpful
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
      1. Menu
      2. Cam settings
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • 2helpful
    2answers
    I have a new memory card. I cant get pictures
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    2answers
    Camera screen said SD card is locked when I installed an SD card
    The SD card has a lever on the side of it. Move it to the other position.That is to prevent accidental erasing.
    Problems Saving data to SD card
    The only other thing you havent mentioned is wether or not you have formated the card first.
    Top Polaroid Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Tom Shanks
    Tom Shanks
    Are you a Polaroid Camera Expert? Answer questions, earn points and help others
