Kitchen Appliances - Others Logo
Question about Philips Kitchen Appliances - Others
My Phillips kettle does not boil water but the light turns pOn. It is electric
Posted by gagandeepche on
Hans Pearson
  • 2,510 Answers
Very simply, it sounds like the element has blown. If the element is built into the base of the kettle I am afraid it is terminal, if it is a calrod type element that you can see in the kettle, it can be replaced.
Posted on Jan 21, 2011
Does not boil water
Our kettle light comes on but not boiling water
1helpful
The switch does not automatically turn off when the water boils. If left alone all the water will boil out.
The switch has to turn off when the water boils as the heat generated must cut off the switch. If this wont work the bimetal is not working and the switch is not responding.
You will need to replace the switch. Please contact the dealership for the spare.
check this link for spare:
http://www.espares.co.uk/brands/kettles/p/1102
5helpful
2answers
I have a new Bellini electric kettle. When I turn the kettle on, it starts to boil for a few seconds and then turns itself off. It will boil if I hold the "button" down for a while until it...
Unfortunately the problem is in the switch mechanism, and will need to be replaced to correct the problem. My sense is it would be cheaper to replace the kettle than trying to find somebody to repair it.
1helpful
2answers
When filled with water & put on to boil it start's boiling as normal then after 10 or 20 secs.the lights inside flicker off and the kettle ceases to boil then the lights flicker back on and boiling...
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
5helpful
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
2answers
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
3helpful
2answers
Water kettle does not boil water
I had the exact same problem. The kettle would warm water but not boil. I bet you have hard water - try putting 1/2 vinegar and 1/2 water mix and turning it on. I did this, fixed the problem!
3answers
Electric cordless kettle
This can happen on new mettalic kettles, the aftertaste may dissapear after a while with use as it did with mine.
2helpful
Light switch on Breville SK500-XL Kettle
e mail [email protected]
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
Top Philips Kitchen Appliances - Others Experts
Thomas Perkins
Thomas Perkins
ray gallant
Kardoc
Are you a Philips Kitchen Appliances - Other Expert? Answer questions, earn points and help others
