Question about White Sewing Sewing Machines
This morning, I successfully used my White 423R for the first time in many years! However, now I need to fill a bobbin, and I can't seem to "disconnect the Hand Wheel from the sewing mechanism by turning the Stop-Motion-Knob towards [me]." It is really tight... should I try lubricating? Where? Or am I just a weakling?
Posted by Susan Hamilton on
R.A. Ellis
  • White Sewing Master
  • 12,731 Answers
Do you have manual for your machine? If so, does it specifically instruct disengaging the needle action by turning the inner wheel? Some machines disengage the needle when you flip up or press the bobbin winder. If your machine instructions include turning the inner wheel, be sure you are turning it "counter clockwise" to loosen. It could be that it is frozen. Of course, your machine probably needs lubrication but I doubt that will help with your particular issue. Perhaps applying heat from a handheld hairdryer to the wheel will help loosen it, or you need someone with more strength.
However, you can pick up a standalone bobbin winder (SideWinder) avlb at JoAnn's or Amazon for ~$30 that is either electric or battery operated. It's a handy little gadget since it allows you to quickly wind multiple bobbins at a time, saves wear and tear on your machine, plus allows bobbins to be wound without having to unthread the sewing machine.
Posted on Nov 11, 2017
5 Related Answers
Anonymous
SOURCE: kenmore sewing machine
My belt is slipping
Posted on Mar 09, 2008
Anonymous
  • 323 Answers
SOURCE: Stop Motion Knob
Dear Jim,
I'm sure you have a pair of Channel lock pliers around.Place a fairly thick piece of fabric around the inner knob to keep from scratching it. Grasp it with the pliers while holding the handwheel and turn it to the left. IF you can't hold the wheel to keep it from slipping, place a screwdriver or something else under the needle set screw area, turn the wheel until the set screw is resting against the set screw and then turn the inner knob with the pliers.
sewman7
Posted on Sep 03, 2008
Anonymous
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
Rob Ristin
  • 97 Answers
SOURCE: my thread gets stuck down in the bobbin area.
Ensure that you are threaded correctly, set your tension for roughly 4.5 and "floss" your machine when threading by grabbing the thread by the needle immediately prior to threading the needle with your left hand, and the thread on the top by the spool with your right hand; then pull the thread back and forth briefly.
Ensure that your bobbin is in the bobbin case in the correct orientation.
Ensure that your feed dogs are in the "up" position. Many inexpensive machines do not have the option to drop the feed dogs, and I believe your kenmore to be one that lacks the option, but consult your manual just to be sure.
Also make sure you're using a good quality thread. Use a European thread, and definitely avoid anything from the dollar bin or any kind of "dual duty" type thread. Cheap thread causes nasty nasty things to happen to sewing machines.
If none of these fixes solves your problem, let me know; but going through the above will solve 99% of problems like you're describing.
Good luck,
-R
Posted on Mar 11, 2009
Mimito7
Kelley Buchanan
  • 130 Answers
SOURCE: Where can I purchase a bobbin for the Mighty Mender W100 Mechanical Sewing Machine
Well, here's an easy fix. It is either a class 15 or class 66. I would go to a local repair shop with your machine and they can try either of them . They are not real expensive.
Posted on Apr 20, 2009
Machine eats bobbin thread
computerized so could be anything
tension or sewing action parts needs a service
Apr 28, 2017 | Janome Magnolia 7330 Sewing Machine
White sewing machine model 1805 can't get it to sew the wheel turns and belt is ok . It is like the wheel is frozen Do you change it after filling a bobbin?
If I recall correctly, to fill a bobbin you must first release the belt from the wheel by loosening the knob on the small machine wheel. Then after the bobbin is filled you need to tighten that knob again. Do you have the manual?
May 27, 2013 | Sewing Machines
I rethreaded bobbin fine but I can not get into bobbin area. Activa 135. The part that has the pole on it to load bobbin will not stay stable. Parts keep falling out of machine. Help
if the hook & hook race are not in the machine stationary then the machine needs to be check to find out why there not staying in there position
& since the machine hasn't been used in years it needs to be serviced
Apr 03, 2012 | Sewing Machines
I plugged in my machine after it had been sitting idle for about a year. I have power and can hear the motor turning, but the needle doesn't move. It acts like a 'clutch' has been disengaged....
does sound like machine is in bobbin winding mode. The clutch may be disengaged by an inner wheel on the flywheel, flicking the bobbin spindle over or a button.
Best thing is to check the manual for your machine as they all vary. Go to http://www.singerco.com/accessories/instruction-manuals/search
then type in the model number with a w in front and click search.
The White and Singer manuals are listed here and many are free downloads as pdfs.
I hope this helps you out.
May 30, 2011 | White Sewing 2037 Mechanical Sewing...
I tried to fill the bobbin with thread and it does not turn. I have used my machine for years and this has never happened before. I tried several bobbins and none worked. Hope you can...
Hi. There is usually a small wire spring sticking out through a slot in the bobbin winding stem which holds the bobbin to the stem. If the stem is rotating but the bobbin is not, chances are this spring may have gotten pushed down too far into the hollow bobbin winding stem or maybe broken or lost.
Feb 25, 2011 | White Sewing 2037 Mechanical Sewing...
Bottom thread way too loose ...
Upper threading is probably not correct. Otherwise you may need a new bobbin case.
Feb 09, 2010 | Sewing Machines
Bobbin won't thread
I just bought my White sewing machine used and the model #967.I had problem winding a bobbin so my husband helped me. what I had to do was hold the arm with the bobbin on up agains the wheel. I know it seems to be a pain but this machine has all kind of attachments.
Apr 01, 2009 | White Sewing 979
Raising the bobbin
Use a SA 156 metal bobbin (ebay, 20 of them for $8.99 free shipping) and make sure the bobbin thread is turning the right direction, read you manual or call singer at 1-800-4singer
Aug 23, 2008 | Singer 3116 Simple
Sewing Machines Logo
165 people viewed this question
Top White Sewing Sewing Machines Experts
Colin Stickland
Colin Stickland
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
