Televison & Video Logo
Posted on Jan 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I try to record back to back programs on different channels the timers won't work. It tells me there is a conflict with the timers and tells me to change priority or whatever. I can set a manual timer and put an hour between shows and then it will work. For example, if I'm trying to record football games and 10 and 17, I can start a manual timer at 6 instead of 5:30, when the other game ends at 5, and it will record from that point on.
Anonymous
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Expert 358 Answers
  • Posted on Feb 17, 2011
Anonymous
Expert
Level 2:
Legend:
Answers
358
Questions
0
Helped
141469
Points
438
Lpierson382
You can check the start and end times on your receiver to see if the timers are setup to begin a few minutes early or end a few later than the actual program time. This would cause a conflict if you are trying to record back to back shows.
To access the screen, press the DVR button to bring up the DISH On Demand screen. Press 1 (My Recordings) on the remote. On the My Recordings screen, highlight the Schedule button on the right, press Select. On the Daily Schedule screen, highlight the Timers button on the right, press select. On the Timers List screen, move the cursor into the box with the list of timers and select a timer, press select. On the Timer Event screen, highlight the Options button, press select. On the Timers Options screen, this is where the early and late activity is set. Change the numbers to a number that will work for your needs. Once completed, highlight and select Done; then exit out of each screen. I hope this helps.
Ray Calo
DISH Network
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Jan 29, 2011
Anonymous
Contributor
Level 1:
Answers
24
Questions
0
Helped
7333
Points
31
Hi this is Luke.
DVR Priority settings are used to prioritize timers should there be a conflict between timers. The top of the list is the highest priority and takes precedence. The bottom of the list is the lowest priority. A lower priority timer will not fire if there is a higher priority timer at the same time. Timers that conflict with each other will display Attention 532. The message may display when switching from Single User Mode to Dual User Mode because the receiver recalculates timers for conflicts.
  1. Press DVR three times on the remote (twice for a 942 receiver). The skip timer icon (red x) designates a conflicting timer.
  2. Select Timers.
  3. Select Set Priority.
  4. Select the timer to change.
  5. Use the Up and Down arrow buttons on the remote or the Move Up and Move Down options on the screen to move the timer priority one at a time. Use the Move to Top and Move to Last options on the screen to make the timer top or last priority.
  6. Select Done.
Selecting Automatically resolve by priority will allow the receiver to set the priority level of the timer. The last timer created will have the lowest priority level and will not be recorded if both tuners are being used for other higher priority level timers.
Selecting Change the priority of this timer will allow the customer to set the priority level of the timer. With the new event highlighted in the Daily Schedule screen (the event will display with the skip icon), press Select. Select Restore and then Yes. The new timer will now have a higher priority level than the conflicting timers.
You may also want to resolve the conflict by:
  1. Press Menu on the remote.
  2. Select Daily Schedule.
  3. Select Timers.
  4. Arrow over and select the timer that needs to be edited.
  5. Select Edit.
  6. Make the desired changes then select done.
Let me know if this help.
1helpful
Logik recorder - error message - cannot schedule recording, there is already a timer at the same time on this channel. turned the box off at the wall & retuned. Any suggestions? Thank you. x
check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to 9.35.day xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
4answers
It will not timer-record some channels such as Channel 5-2 and 9-2. I can manually record on those channels, but when I try to record using timer programming, it won't record those channels.
If Toshiba offered you a refund due to the alleged bug, I doubt that there is a work around to the problem. If it had been a regular tuner I would have suggested that you scan all the channels to commit them to memory.
The problem basically is that those channels re not in the recorder's tuner memory. You can enter them manually but when you try to use the programming the unit will not do it since channels are not in memory. Check your manual to see if there is a provision for getting channels into the memory of the unit. Don't hold your breath.
Set vcr to record after timer is set
You need to turn off the Timer and then add your new program to the schedule. Then turn the Timer back on (power off).
On most VCRs, the Timer is enabled by turning off the unit. Thus turning it on will work (as long as a program isn't currently being recorded). If a program is currently being recorded, press Stop to interrupt the programmed recording. Then add your new program - that doesn't conflict with other programmed recording or exceed the number of available timed recordings for the unit. Then turn off the unit.
At least one VCR I owned was a bit trickier. You had to press the Timer button on the remote instead of the power button.
I hope this helps.
How to program intermatic pe 153p
PE153 comes with P1353 timer.
The timer instruction manual is too long to copy.
Read manual, and add a comment with specific question about any part of manual.
Add as many comments as needed.
http://waterheatertimer.org/pdf/P1353ME-instructions.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
P1353 is 3-channel timer.
3-channels means that timer can control 3 separate circuits, each with different timing schedule.
Timer has 5 different modes.
Page 13 of manual shows modes.
Select different modes depending on what type of device(s) you are controlling with timer.
For example, 2-speed pool pump, you select MODE 2 or MODE 4
http://waterheatertimer.org/images/P1353ME-2-speed-motor-500.jpg
By selecting Mode 2 or 4, the timer protects against programming conflicts that would turn on both speeds at same time, and cause electrical problem.
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
3answers
Hi, I have a Dayton # 2VJ58A Ditital time switch,can I program P1 and P2 with some of the same on and off times during the week. How does the timer know which times to follow when it is put back to the run...
Dayton 2VJ58A is a small, expensive 2 channel timer.
My understanding is that 2 channel timers are made "for the independent control of two circuits." I assume the advantage of multi-channel timers is needing just 1 timer on the control board.
If you are using 2 channels to control one circuit, I don't know the outcome, or if the 2VJ58A is made to do that job. It may ruin the timer!?! Be careful.
The less expensive ST01C timer offers 40 programs per week where overlapping times can exist on same load. These timers advise not to program overlapping times, ST01C troubleshooting says NOTE: Your switch timer automatically skips any conflicting ON event
Dayton timers are made in Japan but I could not locate a web site other than Grainger who sells the product. Probably the timer manual has manufacturing info. Grainger sales might be able to help?
http://www.grainger.com/Grainger/DAYTON-Electronic-Timer-2VJ57
Solution: I would call the seller, or Grainer, or the manufacturer. They might know about the software parameters. I would re-read the instructions carefully, and read up on multi-channel timers before putting power to the timer.
Let us know what you are trying to accomplish with the timer, and maybe we can help from that standpoint
2helpful
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
1helpful
Timer programming problem
Check to see that you have not changed the default choice for input on power up of the box the "timeshift default device". If you have it set to front or rear CVBS or S-video input, it may ignore the channel choice you make when setting up the recording.
tom
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
