Optics Logo
A
Anonymous Posted on Jan 21, 2011
Rarely used Tasco 3087GY Binoculars. The problem is that it feels like you are looking cross eyed when using. Each eye can be focused perfectly independently but when looking with both eyes, it's like you're looking cross eyed. And it's not just me, it's everyone that uses them. I see no way to adjust. SMS
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
763
Points
EARTHS TRANSFORMATION INTO THE 5TH DIMENSION I WOULD LIKE TO SHARE WITH ALL THE OCCUPANTS OF MOTHER EARTH THE
REASONING BEHIND THE "DOUBLE SHADOW". MOTHER EARTH HAS BEGUN A
SERIES OF EVOLUTIONARY TRANSFORMATIONS, ONE OF WHICH IS
AFFECTING THE NORTH POLE, OR MAGNETIC POLE, THE REASON FOR THE
NOW "QUADRUPLE SHADOWS" IS THE EARTHS ROTATION SPEED. EARTH IS
PREPARING FOR A DIMENSIONAL SHIFT, FROM A 3D TO 5D. HENCE THE
REASON FOR BINOCULARS TO SHOW DOUBLE IMAGES, THEY AREN'T BROKEN,
THE "FUZZ" OR "FREQUENCY SNOW" ALL AROUND, VISIBLE TO CAMERAS,
RECORDERS ETC. THE SHADOW ENHANCEMENT AND VISUAL INTAKE OF SUCH,
ALSO SEEMS THAT BLURRY IS EVERYWHERE, IT IS NOT YOUR VISION, IT
IS THE MAGNETIC ENERGY , NOTHING SEEMS TO WANT TO FOCUS, SEEMS
AS THOUGH THERE IS A MIST OR FUZZY FILM EVERYWHERE. tHESE ARE
THE PHYSICAL SIGNS OF THE EARTHS NATURAL AND NECESSARY CHANGE.
NOW IS THE TIME FOR ALL TO FILL THE EARTH WITH LOVE, LIGHT
HAPPINESS AND INNER PEACE. I PUSH INTO ALL OF YOU , HAPPINESS,
JOY AND LOVE. lIGHT SHALL BEAM THROUGH AND AROUND ALL OF YOU
AND YOURS. POSITIVITY AND AWAKENING TO ALL WITH LOVE.
1helpful
I see double image unless I take the lens as close as the binoculars can go
thats how binoculars are. Yours in this case is really strong. the closer you are to something, looking at it, the more magiflyed you going to be. try view things far a distance, really far away. no more double right?
Everything you need to know to become an expert:
on this website: http://www.chuckhawks.com/binocular_basics.htm
It is surprising how many people do not know how to focus binoculars correctly. There are two common focusing systems used in binoculars.
The first is individual eyepiece focus. This system is simple to understand, and easy to manufacture. It also lends itself well to sealed optical tubes, and thus is usually the focusing system used for waterproof binoculars. Individual eyepiece focus means that to focus the binoculars to your eyes, you simply focus the left eyepiece to your left eye and the right eyepiece to your right eye. There is no centrally located focusing mechanism. It is done like this. Look at something in the distance. Close the right eye (or cover the front of the right binocular), and focus the left eyepiece to your left eye. Close the left eye (or cover the front of the left binocular), and focus the right eyepiece to your right eye. You are finished, until you need to look at something at a different distance, in which case you need to repeat the process.
Because individual eyepiece focus is time-consuming, center focus is more common. Unfortunately, very few people understand how to correctly use center focus binoculars. Here is how it is done. Aim your binoculars at something in the distance. Close the right eye (or cover the front of the right tube), and focus the left side of the binocular to your left eye using the center focus control, which is concentric with the pivot shaft between the binoculars. (Note: the left eyepiece itself does not focus on center focus binoculars.) Next, close your left eye (or cover the front of the left tube), and focus the right eyepiece to your right eye. DO NOT touch the center focus control while you are focusing the right eyepiece to your right eye. Now you are finished. What you have just done is adjust the binoculars for your individual eyes. (Practically everybody's left and right eyes are different.) From now on, you only need to adjust the center focus control when you look at things at different distances. Center focus is faster and easier to use than individual eyepiece focus, once you have initially set the binoculars for your eyes.
Binoculars are commonly described by using a pair of numbers, as in "7x50" or "8x25." The first of these numbers refers to the magnification offered by the binocular. Magnification is why most people buy a pair of binoculars. In the examples above, "7x" means the binocular makes whatever you look at appear seven times closer than it does to the unaided human eye. "8x" means the binocular makes whatever you look at eight times closer than the unaided human eye. "10x" makes things look ten times closer, and so on. The first number used to describe binoculars always refers to their magnification. Common binocular magnifications are 6x, 7x, 8x, 9x, and 10x.
There are also variable power (zoom) binoculars, such as 7-21x50. These almost always perform much better at the low power setting than they do at the higher settings. This is natural, since the front objective cannot enlarge to let in more light as the power is increased, so the view gets dimmer. At 7x, the 50mm front objective provides a 7.1mm exit pupil, but at 21x, the same front objective provides only a 2.38mm exit pupil. Also, the optical quality of a zoom binocular at any given power is inferior to that of a fixed power binocular of that power. In general, zoom binoculars are not the bargain they seem to be.
Remember that everything (including movement) is magnified when you look through a pair of binoculars, especially your own shakes and tremors. So the higher the power, the harder it seems to hold the binoculars steady. 6, 7, or 8 power binoculars are easier for most people, even those with very steady hands, to hold reasonably still. The higher powers sound like a good deal, but often result in jiggly, blurred views. This is why 7x binoculars are chosen by so many experts, including the military.
Power affects brightness. Other things being equal, the higher the power, the dimmer the view. And power also affects the field of view of the binoculars. Again, everything being equal, the higher the power, the smaller the field of view. So, as you can see, power must be balanced against other desirable characteristics when choosing binoculars.
2answers
Seeing double when I look with both eyes. Out of
Step 1.
Adjust the eyepiece or both if both are adjustable back to zero. It should be printed on there. If it's not, then halfway. To find halfway turn them to one end, count the number of turns like 1 and a half turns for example, and then half that atnd turn it that ammount. You've now reset the binoculars to zero.
Step 2.
Now to focus. Pick your target that you want to look at thoguh your binoculars. Look through the binoculars and close the eye with the adjustable eyepiece or your right eye if both are eadjustable and focus the image on the left eye with the central focus knob. Once you've got it focused close the left eye, open the right eye and if it's not in focus adjust the EYEPIECE focus, not the central one, until it's in focus.
If you can't get it in focus because the eyepiece focus won't turn far enough in one direction, turn the OTHER eyepiece in the opposite direction at max, start the process again from step 2.
If it's all ok now you need to adjust the distance between the eyepieces. Open the binoculars as far as they go, look through the binoculars with both eyes on the target and move the binoculars inward slowly until you remove any black edges around the image, then move them very slowly inward until you see only one image.
If you've got more problems come back as ask. :-)
I have to hold my 8 x 42 bioncuklars about 2 inches from my eyes to see thru them
Here are some instructions for setting up binoculars for your own eyestrength..
This is more common than you would think.. Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
1helpful
One side won't focas
You don't say what model binoculars you have, but there are two possibilities (well, three, but the third one is that your binocs are broken - lets try the other two first!)
Some very fine binoculars have individual focusing for each eyepiece. You focus each side for your eyesight. If that's the case with your binoculars, there won't be a central focusing control.
If you DO have a central focus knob, it's possible that your binoculars have a "diopter" focus on one or the other eyepiece. Look at the rim of the eyepiece for a marking that looks like "+ . . . | . . . -" or something similar. What you want to do is focus the binocs using the central control so the the UNMARKED eyepiece is in focus for you (close one eye to focus), then switch eyes and focus the marked eyepiece by rotating the eyepiece rim until both eyes have good focus.
Binocular manufacturers do this because many people have better vision in one eye than the other, and many people also prefer to use binoculars without their glasses. Hope this helps.
Each eye is clear, but they aren't lined up right...it is like being crosseyed.
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Hope this helps...
1helpful
Double vision in minolta binoculars
Hope this helps...
Cannot get them into clear focus
Hope this helps...
1helpful
I bought these for my husband. In trying them
Difficult to answer specifically without knowing the model. But binoculars are designed to view objects in the distance. They all have a limit as to how close they will focus based on the magnification and design. Objective lenses that are far apart such as on a porro prism binocular will not focus very close. The nature of the design of having the objectives further apart than the eyepieces doesn't allow it. When trying to focus too close the image will appear blurred and double. That is the nature of the design. 9 feet or 3 metres is considered quite close to focus a binocular and is usually for a model designed to do this such as a roof prism where the objective lens and the eye lenses are inline. A specialty binocular such as the Pentax Papilo will close focus to 50 centimeters. It has been designed so that the objective (large lenses) lenses converge.
Take into account when focusing that binoculars are also designed to compensate for differences in each eye. One of the eyepieces either right or left will adjust seperately. For binoculars with a center focus ring. First focus using the center ring with one eye covered. The eye that should be covered is the one that doesn't have the adjusting eyepiece. When the image is clear close the eye you have just used and leave the center focus alone. Focusing on the same spot look through the eyepiece that adjusts and turn the eyepiece ring until the image is clear. Now all you have to do is focus using the center ring only as the binoculars are adjusted for each eye.
Some binoculars do not have a center focus and each eye will adjust seperately.
Jul 29, 2009 • Optics
Differnt focus for each eye?
All binoculars (except some really cheap rubbish) have a different focus for each eye. There are two types. Binoculars that have two individual eyepieces that turn and no center focus wheel. This is common to military, astronomy and binoculars used at sea.
The other is the usual center focus binoculars that have a wheel between the two barrels. They will also allow either the left or right eyepiece to turn to focus for one eye. The reason is that manufacturers take into account that each eye is slightly different.
Jul 04, 2009 • Optics
27helpful
2answers
How to focus my Zeiss 10x40B TP binoculars
Your binoculars are known as the Zeiss Classic or what was once known as the Dialyt. They focus differently from the usual binoculars like those mentioned. The rear wheel is to focus both binocular barrels while using them. The front focus wheel is adjust the right eyepiece to suit your right eye. Binocular manufacturers take into account each eye is slightly different. To focus the Dialyt...First close your right eye and turn the rear wheel until the image is sharp in the left barrel. Leave the focus wheel alone. Now close left eye and adjust the front wheel until the image is sharp for your right eye. The image should now be clear and in focus for both eyes. It should not be needed to use the front wheel from now on. The rear wheel is what you will use to change the focus from near to far objects.
Top Tasco Optics Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Tasco Optic Expert? Answer questions, earn points and help others
