Question about Aqua Vu Scout SRT Fishfinders
It powers on but the screen does not turn on.never has worked since we bought it. called the teck service said that not possible so my buddy gave up on it.I put a new battery in it green lite comes on but screen doesnt lite up check fuse in back and on face still no good .I give up.
Posted by murfs676 on
Anonymous
    New Friend:
Check the battery voltage. It should read around 12 volts. I have the same unit that did the same thing. The battery voltage was down to 6.5 volts. That was enough to power the LED but not enough to run the unit. Once I used a known good battery everything worked fine. Good luck!
Posted on Feb 08, 2011
Bought a phone LG K-7 off friend how to reset original email/password so my email will work or is it possible
Go into settings and under accounts, remove the email account there and then you can add your email .
Mar 27, 2018 | LG Cell Phones
6600 power switch jumper
here buddy
hope it helps...
Jun 03, 2011 | Nokia 6600
I JUST BOUGHT A MICROWAVE GMH5205XVS. IT STOPPED WORKING AND GAVE US CODE F7. DO WE NEED TO CALL FOR WARRANTY REPAIR, OR IS THIS SOMETHING WE CAN FIX.
There are many reason for this course however,this means that the oven has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the beeping sound, then try turning the oven off and on again. If you still see the "F," turn off the power to your oven and wait five minutes before turning it on again. If you hear the beep or see the "F" when you try to bake or broil again, please call your authorized provider for service.
Please rate this solution.
Good luck.
Dec 27, 2010 | Microwave Ovens
Can't pair it with controller. I bought a white ps3 controller from hong kong. it will turn the system on but thats it, no buttons work. At first I thought it was because the controller was from overseas,...
if the ps3 reads ps2 games then it's a 60 gig,and has 4 usb ports rather than 2...if the controller works on a buddies machine and the machine freezes,it probly needs a service.
Sep 17, 2009 | Sony Playstation 3 (PS3) Console
Power Button Light Flickers, wont' turn on
Your monitor has a common problem, the power supply board is blown. Because of the heat trapped inside the monitor parts called capacitors have been damaged. We have a repair guide on our web site for the Samsung 214t series and your 204 is very similar and they use the same parts to repair them. Check out our site at: www.ccl-la.com/badcaps.htm
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 28, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
LG CU500 Instant Messaging Help
I had the problem with my Cingular LGCU 500. I called AT&T they had to go into my account and enable the ability to download on my account because I had never used the feature. Hope that helps.
Dec 08, 2008 | LG CU500 Cellular Phone
No Picture or Sound from ASTAR 32 inch LCD Television
There is more than one problem with. A it could be the main board that finally gave out. B the power board in your TV is not work, and now you can see a picture. Depending on how it's connect the screen could be burn out. but just what type of light comes on when you try to turn it on. if the green light comes on and stay on then it has to do with the picture not the power if you need help narrowing down the problem you can call 226-2211 My E Discounts. I'm a tech and we work with a Astar TV from time to time.
Aug 28, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Samsunng 940mw lcd monitor will not power up. was blinking several times before it would turn on. now no power light nothing.
I experience the same "power on" problem with mine, bought february 2007.
Just called the Dutch servicedesk of Samsung Electronics, just gave the serialnumber, next tuesday I will receive a new monitor.
Thumbs up this time for Samsung service
Jul 21, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
How do i wire a computer
hi buddy!
checked the cable if already connect to the videocard and also the power supply
May 28, 2008 | EliteGroup RS482-M754 Motherboard
Powers on, screen flashes Akai screensaver and then shuts off
Take the unit into the service center - have the service center diagnosed the problem - they will order the part - but the parts are not available - DONT WAIT - The manufacturer must exchanged the unit because the the manufacturer must provide the parts for up to 5 years by law after the the tv is manufactured. Have the service center provide you with a workorder stating the television is not repairable because the parts are not available - then call 800-726-4405 - they will start hte process to exchange the televsion - LONG PROCESS to get an exchanged television
Feb 24, 2008 | Akai LCT3201TD 32 in. LCD Television
Aqua Vu Scout SRT Fishfinders Logo
267 people viewed this question
Top Aqua Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you an Aqua Boating Expert? Answer questions, earn points and help others
