Question about Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103
Kenmore dishwasher elite door opens too fast, broken spring?
Posted by wallace272 on
Hans Pearson
  • 2,510 Answers
Could be that, the spring may have unhooked or it could be a defective damper connected to the door. Remove the side panels and check the operation of the door mechanism. (This will probably require the removal of the rear panel to gain access to the necessary fastners).
Posted on Jan 21, 2011
How do I repair the spring that holds dishwasher door?
The door spring can be seen on the side of the frame just below the bottom of the door. If the spring has just popped off you can put it back easily when the door is open. If the spring has become weak, you can get a new one from an appliance parts store or online.
Jun 10, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
How can I adjust the weight on the integrated door
there are springs with cables in most dishwashers i never had that problem but i did replace one spring that had broken. making it fall to fast. its no to hard if your handy. most appliance parts stors if there good should be able to help if they can be adjusted
. Contact Us - Kenmore
http://www.kenmore.com/customer-care/nb-100000000410025
not sure why but i can,t see brand of your dishwasher
Mar 08, 2015 | Dishwashers
Kenmore elite dishwasher model 665.16493300 door falls to floor when opening
Door springs are located at the left and right side of the door bottom. You will have to pull the unit a few inches from the installed location to see them. If broken, replace. If one slipped off, reattach.
Mar 09, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
DISHWASHER DOOR OPENS REAL HEAVY AND FAST
It sounds like your door springs are broken, at the top of the dishawasher you will find 2 screws that attatch it to the counter top, take them out and slide the dishwasher a few inches forward, this will allow you to see if your springs are broken. If so you can order new ones at marcone.com w/ your model #
Nov 09, 2010 | Dishwashers
Door spring broken
the door links are broken need to get new ones and replace
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Dishwasher 630 1630 9400 Soap Dispenser Problem
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
May 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Need to replace door spring
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
Nov 24, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103 Logo
445 people viewed this question
Top Kenmore Dishwashers Experts
Ron Rak
Ron Rak
Marvin
Marvin
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
