Question about HP Office Equipment & Supplies
My hp deskjet D1360 is not printing,when i give print comand,message showing printing 1 of 1,but no print,power indicator green light continuosily blinking,before giving print command,but when i close the top cover green indicator is always on & head goes to one side.please help
Jeff Bird
  • HP Master
  • 1,346 Answers
Hi try this . cheers
my hp deskjet D1360 is - camerazoom-20180306220043522-qojfh2rnjfq4llujl0n5mebo-3-0.jpg
Posted on Mar 06, 2018
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: HP Deskjet 5150 - top cover open
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Posted on Sep 16, 2008
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: hp deskjet d1360 printer installer
Select your operating system and download from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1119266&lc=en&cc=us&dlc=en&lang=en&cc=us
Dont forget to rate this a Fixya if it helped!
Cheers!
ID
Posted on Nov 17, 2008
Anonymous
SOURCE: My HP Deskjet D1360 printer
bos dimana tempat download driver hp deskjet 1360
Posted on Dec 25, 2008
Anonymous
SOURCE: Download HP Deskjet D1360 Installer
i need the installer printer hp 1360,couse my cd was broken
tahir mir
Posted on Oct 10, 2009
Anonymous
  • 787 Answers
SOURCE: hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Posted on Nov 04, 2009
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
My printer hp deskjet d1360 offline status and the lamp is blinking
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Dec 22, 2010 | HP Deskjet D2360 InkJet Printer
The printer light keeps on blinking continuously
goto control panel and click on printers or printer or faxes. when you open this folder your printer is shown double click on it and select all the previous print comands and if all comands will not removed switch off ur printer and the try again . and if the problem is same then unplug or plug ur usb data cable or if the problem can't be resolved the change ur data cable.
Jun 27, 2010 | HP DeskJet 3550 InkJet Printer
I have use the HP Deskjet D1360 series printer paper jam
Simple and slowly remove the jamm'ed paper. Please be sure to inspect the system in detail (you may need tweezers) for any small pieces of random paper laying around.
After this you should be set please let us know if this issue persists as this would be a sign of other issues.
Thanks
Frank
Live-Tech
1-888-361-8511
May 24, 2010 | Office Equipment & Supplies
What is the process take test print of hp deskjet D1360 in offline
Most of the HP's you just hold the resume button a few seconds and when the power light flashes it will make a test print.
Dec 16, 2009 | HP Deskjet D2360 InkJet Printer
Hp deskjet d1360 un able to print,soft ware not exist want to down load
You can download the driver for your HP Deskjet D1360 here:
http://drivers.softpedia.com/get/PRINTER/HP/HP-Deskjet-D1360-Printer-Driver-7-0-2.shtml
Nov 30, 2009 | HP Office Equipment & Supplies
Printer is not printing but power light is blinking
Try to restart computer first then printer.If not help reinstall the drivers.
Oct 22, 2009 | HP Deskjet D2360 InkJet Printer
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
Apr 15, 2008 | HP Deskjet D2360 InkJet Printer
656 hp deskjet does not print
please replace the catriges with new orginal before replacing please clean the catrige inner part with cloth+water then replace new orginal one and then on.
please check the drivers is installed or not
start-setting- control panel down-printer and faxes
check printer drivers is there are not
and then please check it is in ready mode or in pause mode
it should be in ready mode
please give first single page and what you wish
Jan 01, 2008 | HP DeskJet 656c InkJet Printer
103 people viewed this question
Ekse
efs_perpends
efs_perpends
