Question about Samsung SCX-4725FN All-In-One Laser Printer
DOOR OPEN ERROR MESSAGE SHOWING ON SAMSUNG SCX-4725FN PRINTER BUT THE DOOR IS CLOSED
Posted by parts879 on
RAJDEEP DUTTA
  • Samsung Master
  • 2,517 Answers
Hi there remove the cartridge and clean the internal part. Then insert the ink cartridge and try. If you face same problem then reset the Printer and turn off for 5 minutes. Now again turn on and let me know the result.
Posted on Jan 21, 2011
My scx-4725fn printer doesn't print. and gives the error message what should i do?
what is the error message that it gives you ? the most common on these printers is the paper feed error the machine will not pick up paper. the feed tire is right below the toner system and the feed tire gets dirty and wont feed paper. if this is the case the feed tire needs to be cleaned. you should take it to a dealer for this cleaning because it is hard to get to the whole tire with out knowing what to do.
Feb 02, 2015 | Samsung SCX-4725FN All-In-One Laser...
Is the SCX-4725FN compatible with Mac OSX Lion? It works fine with Snow Leopard and earlier versions.
Samsung have only released up to 10.6 at the moment. As per link below there is no supported driver available for 10.7 OSX Lion
http://www.samsung.com/us/support/downloads/SCX-4725FN
Aug 30, 2011 | Samsung SCX-4725FN Printer
Was working fine. Now wont print. IP error?
There are two things possibile, first the waist container is full so you need to empty this.
Second for some reason the printer driver is demaged and you need to replace the driver, now there are two ways to do this, first you use your original printer cd is with the printer at the day of purchase, second you can go to the web; open google and write "samsung printer SCX 4725fn" open the side of samsung and chose the newest print driver version for your printer and download it for installation to your computer; then do the same with the scanner driver and install them both on your computer, now check the funktion.
Apr 11, 2011 | Samsung SCX-4725FN All-In-One Laser...
I HAVE A SAMSUBG SCX-4725fn, and am getting a low heat error
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Jan 03, 2011 | Samsung SCX-4725FN All-In-One Laser...
Paper jam error, check everything but still showing paper jam
turn off the printer
Unplug it
open the paper jam door and gently push the paper roller forward until it clicks.
close the door
wait a few minutes
plug the printer back in
turn it on and see what happens.
I hope this helps.
Aug 18, 2008 | Samsung SCX-4725FN All-In-One Laser...
Two Sided Printing for a Mac computer?
I have the same problem with my Canon ImageRunner 3200
Aug 15, 2008 | Samsung SCX-4725FN All-In-One Laser...
Samsung SCX-4725FN All-In-One Laser Printer Logo
1,739 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
