SOURCE: CITIZEN BL9000-59F MEN ECO DRIVE WATCH minute repeater
Try this link:
http://www.citizenwatch.com/CUK/English/settings.asp
Everything you need for the caliber number and settings is here.
Do not forget to rate, please.
SOURCE: How can I resize a citizen watch with an
If you look carefully on the inner side of expandable bands, there's usually the removable links of the band near one or both ends of the band.
These usually have arrows indicating which direction the locking pin/tab slides to unlock and allow removal.
If you're careful, you can unlock them and remove one or two by using a small screwdriver. A very inexpensive alternative is to find a local watch repair shop and have them resize if for you while you wait. They've got the mini-tools and it's usually very reasonable (around here, there's a couple chain grocery stores that have watch repair kiosks inside..great alternative and cheap).
SOURCE: I need manual for Citizen Chronograph AS4 020 52E
mcdevito75 here, You can try at, www.citizenserv.com for a new manual. Hope this helps.
SOURCE: I have lost my user manual for my citizen MA
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
or
Go to "citizen.com" and click on "watch finder".
Put your watch model into the search box on the left and click on
"search".
Click on the watch to view details.
On the right is a small menu, click on "get technical info"
On the right you you will see a list of instructions you can download
