Fine Digital FineDrive 350 GPS Receiver Logo
A
Anonymous Posted on Jan 21, 2011
Its any softwere update for this fine drive 350 , or any link I can download driver , I dont have the oryginal sd card Thanks Mike
Anonymous
Level 3:
Genius:
  • Master 1,637 Answers
  • Posted on Jan 21, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1637
Questions
Helped
289949
Points
4933
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
2helpful
Travelpilot lucca 5.2
My name is mike. If you do not have a sd card you will need to get one.I would try blaupunkt direct, or possibly places that sell your unit. Also try Car toys, or Best Buy, Radio Shake. Might be able to help you, I am putting down a link below that tells everything you want to know about your unit but as you can see for you to update with out a sd card is pretty hard. Mike
http://www.blaupunkt.de/fileadmin/user_upload/UK/download/guide_luccasoft_0685os1131_en.pdf
Oct 19, 2011 • GPS
2answers
My sony vaio vgn nw26m sd card reader is not working when i insert a sd card it wont read it
Hi
this is what i would do to fix the problem there are several options and ways
start
type in device manager
when in device manager
have a look to see if you can see card reader in there
if not go up to the top row of writings and icons and hover your mouse over the 3/4 options on the right
one of them should say scan for new hardware
hit the scan tab
windows may or may not reconize the card at this stage but dont worry
if you can find it in device manager and it has a yellow warning sign on it
please double click it and go into the properties
then go into the driver
then try to update the driver from there
if it is in there please un install it
Now leaving the sd card in the usb
restart windows
maybe windows will then install/reinstall sd card driver
if not
please do all your windows up dates leaving the sd card in
if this does not work then please click on this link
www.sonyvail.com
go to support/downloads find your model and operating system
find the sd card driver
download it
install it
then restart laptop
hopefully all will be well
many thanks
1 need a sound softwer intaller for pg31 v1.0 becouse i dont have a sound my pc.
You need to get on the manufacture website and look for support tab, and driver download and look for drive for your sound card. Download it and update or install driver through device manager. Good luck.
2helpful
2answers
Unable to access CD/2GB due to drivers how can i stall the driver
you do one thing to install dual o.s in your system and solve your problem
2answers
Nokia 6300 music player wont play from my memory card
Hello i hope u 'll be fine.... thanks for using fixya.
This problem is usually occur when music player don't load data of memory card itself
  • First of all turn off your cell insert your memory card carefully again
  • Turn on your cell, when it 'll be on, open your music player it 'll take some time to refresh
  • Now do in the options of music player
  • Second option 'll be music library open it
  • Go down there 'll be a last option Update Library, it 'll take some time and hope it 'll load all your music and all music files 'll show in track list.
Enjoy
I hope this solution will work and helpful 4 u. Best of luck
Please do rate if if it is helpful
THANKS
I dont know what Pinnacle I have? Dont know how to use it ?
Hello ,check all your materiel name and direct download for softwere in this link :http://www.ma-config.com/accueil_en.html
2helpful
2answers
Driver soft were
Hiya,
Have a look here:
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=227:5:0:0:0:0
Type your printer model in the box.
I'll assume its the X1270, So type that in the box.
This will take you to the driver page.
Select your language and select your operating system.
Once you've selected you operating system it will take you to the most recent driver for your printer.
Click on the download link highlighted in red on the right side of the screen and save it to your desktop.
Once its finished downloading, double click the file and follow the on-screen instuctions..
I hope this helps..
Mike
152helpful
8answers
SD Drivers
Hi! You can click on this link http://tinyurl.com/toshibaSDdrivers so that you can download the driver for your SD card on your Toshiba laptop.
Hope this helps!!!
Thanks
Finedrive 350 system/maps
The CD has everything. You can copy the maps and and the OPSYS to the SD card from the CD. As I have told others, though, the mapset is from 2005 and the man at the factory told me they do not intend to produce an update to the mapset.
Also, the 350 was not made by Fine Tech. It was made by Navtour. In fact, the Navtour 147 is the same electronics in a different package. You can download the mapset at:
http://www.navtour.com/
Top Fine Digital GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
