Question about Radio Communications
I have a Kenwood KDC-2023 and i want to know what each colour wire means and what is their function, also how to connect it to a toyoata camry 1998 xv20
Posted by leilani_tini on
wcrave
    New Friend:
    Problem Solver:
  • 19 Answers
Http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC4023.pdf
This link will get you the owner's manual with the identification of the plug wires.
http://www.metraonline.com/
This link will get you to a company that makes wireing harnesses to attach to the plug wires from the radio to the factory wiring harnes.You can look up your vehicle to find out the parts you will need. You will need an installation kit also.
....Don at NTCB, Inc.
Posted on Jun 29, 2011
IM TRYING TO MAKE MY OWN HARNESS FOR A KENWOOD KDC-MP5032 AND I DONT KNOW WHICH WIRE GOES WHERE. PLEASE SEND ME ANY INFO YOU CAN. THANK YOU FOR YOUR TIME!
the usual colours are:
  • black - ground
  • blue - power ant
  • blue/white - remote power on
  • yellow - +12v
  • red - accessory
  • orange - illumination
  • white - left front
  • gray - right front
  • green - left rear
  • purple - right rear
on the speaker ones the colours with a black strip are usually the negative -
hope ths helps
Sep 21, 2010 | Kenwood KDC-MP5032 CD Player
Need a wiring diagram please
wiring diagram or colour code for kenwood cd player model kdc-5108
Nov 16, 2009 | Kenwood KDC-W3534A CD Player
Need to know what the wiring diagram for kdc-x789
well if you mean how to wire it up to ur car buy a radio adapter from best buy and color match all wires
Aug 31, 2009 | Kenwood Excelon KDC-X789 CD Player
Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
Nov 21, 2008 | Kenwood KDC-MP235 CD Player
Install
Assuming that Kenwood KDC-135 is fully operational then your only concern would be matching the Kenwood wires to the Camry's wiring.
Most Toyota Camry uses the below wiring scheme. I have taken the liberty of including the corresponding Kenwood wires.
Hope that this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 02, 2008 | Kenwood...
Radio Communications Logo
102 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
