Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
It ok we fixed it turned out there was a small nail type thing (from the boys work clothes no doubt) stuck in the hose at the back of the unit was tripping the sensor so it was not working! It wouldnt manually go through the spin either so must have been a safe gaurd but all is good thanx any way
I have similar problem to this also. Not sure what to do?
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
