Question about Sony STR-DE845 Receiver
My Sony Receiver freese up on demonstration mode . Please help!!!!!
Posted by andreyyatsko on
David Dunn
  • 8,546 Answers
It is stuck in demo mode how do I fix the problem
SELECTED PRODUCT: (change your search)
How to disable the demonstration (DEMO) mode.
Article ID: 42707 ' Last Updated: 03/11/2014
Sony® stereo systems will enter the DEMO mode the first time you power on the system or if you do not operate the unit shortly after turning on the power to the system.
To disable the DEMO mode, while the stereo system is powered off, press the DISPLAY button repeatedly until the demonstration display disappears.
NOTES:
  • Depending on your model, some units have a DEMO button that is used to disable the demonstration mode. If your unit has this button, with the power to the system off, press the DEMO button until the display disappears.
  • If applicable to your unit, setting the clock on your stereo system will also disable the DEMO mode.
  • Using the buttons on a supplied remote control will not disable the demonstration mode.
If model-specific information is needed to complete any of these steps, refer to the operating instructions supplied with the product. Manuals, Specifications and Warranty information for your Sony product is available online.
May 27, 2015 | Sony Audio Players & Recorders
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
When i boot the laptop it freeze at the windows logo, i can't restore to, when i do that it will freese allso and when i boot from usb it will allso freese. Please help
Which operating you are using??
Try to restart your laptop in safe mode.(press F8 key repeatedly when you start your laptop ->select safe mode option)
Or You can try this steps also::: press shift key until the windows logo appear on the screen.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 29, 2012 | Samsung NC10-13P Netbook
The reciver is stuck in demo mode. Can`t get it out of demo mode.
The demonstration will activate the first time you turn on
the power. When the demonstration starts, the following
message appears in the display:
“NOW DEMONSTRATION MODE IF YOU FINISH DEMONSTRATION PLEASE PRESS POWER KEY WHILE THIS MESSAGE APPEARS IN THE DISPLAY THANK YOU”
To cancel the demonstration
Press the Power 1/0 button to turn the receiver off while the above message is being displayed. The next time you turn the receiver on, the demonstration will not appear.
It's in the manual - page 3.
Jun 10, 2010 | Sony STR-DE445 Receiver
Whenever i turn off the mains, i get a Demontration message after power on.
From the manual:
Demonstration Mode
DISPLAY THANK YOU”
Press ?/1 to turn the receiver off while the above message
To view the demonstration
Hold down SET UP and press ?/1 to turn on the power.
Notes
• Running the demonstration will clear the receiver’s
memory. For details on what will be cleared, see
“Clearing the receiver's memory” on page 15.
• There will be no sound when the demonstration mode is
activated.
and...
Note: If the AC power cord is disconnected for about two weeks, the receiver’s entire memory will be cleared and the demonstration will start.
Mar 17, 2010 | Sony STR-DE445 Receiver
When i press the tv/sat button the display says unlock. How do you unlock it
Problem fixed,
I turned the unit off waited 10 seconds then turned it back on pressing the power button and set up button together this started demonstration mode.Let the demostration mode run till finished then turn it off again wait 10 seconds and turn it back on.This solved the problem
Dec 23, 2009 | Sony STR-DE545 Receiver
No sound in any mode, sometimes has weird static-like noise that lasts for a second or two. I turned the receiver off and back on and it started working for a while the other day. I also changed the modes...
Follow the steps below to troubleshoot why there is no sound:
    IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
    NOTE: Because each of these steps represents a possible solution to this issue, check the sound after completing each step.
  1. Verify that the Audio/Video (A/V) receiver is set to the correct function or input mode.
  2. Verify that the A/V receiver is not in the demonstration mode.
  3. Check all speaker connections to verify proper connection.
  4. Depending on your model unit, select the main speaker output (A or B) that corresponds to where the main speakers are connected. IMPORTANT: If the main speakers are connected to speakers A on the A/V receiver, the speaker output must be set to A for sound to be reproduced.
  5. Run a test tone operation to test the speakers if your A/V receiver has this feature.
  6. Verify the cables from the source component are connected properly to the A//V receiver.
  7. Connect the component to a different input on the A/V receiver.
  8. Tune the A/V receiver to the new component input.
  9. If the issue is still not resolved, replace the A/V cable between the component and the A/V receiver. NOTE: If all speakers operate using the different input, then the first input on the A/V receiver is not functioning correctly.
  10. Connect a working speaker to the speaker output on the A/V receiver that is not working.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Sep 21, 2009 | Sony STR-DA555ES
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
My navman icn 510 is always on SIM
Your Navman is in Demonstration mode and is demonstrating a route that you have set up. It should be flashing SIM alternately with the time taken on the route so far.
If you don't want the 'Demonstrator' to operate, you can turn it off. See your manual. If you have not got one, you can download it from the Navman site.
I only have the iCN510 and I have to go to the main Menu screen, tap 'Route Information', then Cancel Route to cancel the current demonstration.
To turn off Route Demonstrator from Main Menu icon_arrow.gif Settings icon_arrow.gif Routing icon_arrow.gif next screen icon_arrow.gif Untick 'Demonstrate Route. icon_wink.gif
_________
Oct 23, 2007 | Navman ICN510 GPS Receiver
Sony STR-DE845 Receiver Logo
Top Sony Audio Players & Recorders Experts
aliasger yq
Alvin Barnabas
Alvin Barnabas
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
