Question about Electrolux Freezers
My kelvi FN360 Freezer is icing up on the bottom. Pulled the lower tray out this morning & it & the goods on it were covered in a solid block of ice around 2 inches thick. Occassionally I am also finding small puddles of water under the unit. My guess is that on the defrost cycle the unit is melting some of this ice and its making its way onto the floor. I also believe that the water / ice build up on the bottom is due to there being a blockage in the drain, but I cant find the drain opening in the cabinet. I can see where it empties in the tray above / around the compressor though. I've tried cleraing / locating the inlet by placing some whipper snipper cord up into it, but alas this was not fruitful. HELP ME PLEASE!!!!!
Posted by coontakinta7 on
2 Related Answers
jumptrout51
steve
  • 3361 Answers
SOURCE: frozen water on the bottom of my Amana freezer
Your drain line is clogged. Take a small diameter pice of wire and snake out the drain line from inside the freezer.
You may have to access the back rear near the compressor and separate the drain line there and clean it further.
Posted on Apr 07, 2009
Anonymous
  • 115 Answers
SOURCE: Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Posted on Aug 05, 2009
How do I fix freezer drain in Kenmore Elite french door refridgerator
Hello John;
My name is Peter. I am a retired field service refrigeration technician.
A frozen or blocked drain may not be the problem, or it may.
You have one of two problems. Regardless of which problem it is you need to remove the back wall panel in your freezer. This is not a easy task. You must remove the freezer door, the ice maker, the side guide rails. There are two clips on the back wall air distribution center section using a screw driver to depress and then some. You need to install a hot wire from the bottom of the defrost heater to the drain. Do not attempt this, you may damage some of the components if you do not have the experience.
Ok, lets check out the frozen drain the easy way. Your unit goes through a defrost cycle every 8-10 hours. This is where everything shuts down for 20-30 minutes with the exception of your lights. Your defrost heater turns on during this time.
1.) Check the Drain:
a.) Pull your unit out from the wall to where you can get behind it. You may have to raise up the leveling jack screws in the front to do this. Remove the bottom toe plate. There are two Philips head screws holding it on. Turn the jack screws counter clockwise to raise.
b.) Having pulled the unit out from the wall, unplug the unit. Remove the bottom back cover. There are several hex head screws holding the cover on.
Pull the drain tube out. It just Pops in and out. If there is a black rubber grommet at the discharge end, remove it and throw it away. The initial intent was to keep warm air from getting into the freezer. However, over time they dry up and prevents the condensate from draining.
c.) Insert a wire up into the drain hole, such as a coat hanger, to check for blockage. If it is blocked with ice, you must unplug your unit for 24 hours to completely clear the ice.
2.) Obstruction or Refrigerant Leak:
Recently, I believed my friend had a frozen drain in the same unit that you have. Upon pulling the back cover I discovered a block of ice build-up at the refrigerant and capillary tube connection. The capillary tube is about 1/16" in diameter with a small needle size hole running through it. This tube can easily become plugged, which is common. This block of ice will continuously drip. A repair of this nature is about $450.00 - $550.00. The rule of thumb is: "If the cost of repair is 1/3 or more of the original cost of the unit, then replace the unit. You can get some good deals at a Sears Outlet (Scratch & Dent) Store.
Jan 19, 2015 | Kenmore 25 cu. ft. TRIO French Door Bottom...
Fridgidaire freezer warming up
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 09, 2013 | Freezers
Hi! My kelvinator FN360 frost free freezer's motor is running all the time and it is not freezing inside properly.Occasionally, there is a pop coming from the freezer (most of the items are frozen though)...
check your door seals. warm air leaking in can keep it from reaching it's temp. also, the condensation will collect on the evaporator coils causing them to freeze up. when they do, there is no air flow to cool the rest of the fridge, so the compressor will run constantly trying to reach the set temp. empty it out, thaw out the coils, and check your door seals for leaks. if it still happens, you might have a slow freon leak.
Nov 10, 2009 | Freezers
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
Aug 15, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Ice maker is making ice cubes AND pouring water
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Aug 07, 2009 | Freezers
Hello, we have a three year old LG GR-359SQ Fridge freezer. Firstly, everything works fine with the unit but at the bottom of the freezer compartment is a 30cm x 30cm by 10mm deep trough that in a space of...
Try adjusting the levelers on the bottom I like to see 1/4 bubble on a level if you don't have a level no problem just so it slopes to the back. good luck Tom
Jul 02, 2009 | Freezers
BEKO AB910 Frost Free Fridge/Freezer Ice build up
I have the same model + problem. You should not need to defrost this model manually if it's working correctly, but the ice build up you describe is probably due to a blocked pipe in the auto-defrost system at the back. You need to defrost properly to prevent recurrence.
Behind the upper freezer drawer there's an aluminium tray behind a plastic grille. Every few days this tray warms up to melt any accumulated ice behind this plastic grille (full height of the freezer). A pipe should take the meltwater down to a plastic tray below (pipe + plastic tray are visible if you take the lower panel off the back). Your problem is too much ice blocking that pipe: the heater can't cope and it doesn't melt, so the ice 'cascades' down the back behind the bottom drawer.
When you manually defrost, you must ensure that this pipe is clear, otherwise the auto-defrost won't work, and you may have to defrost manually again within days.
I have found that the best way to defrost the pipe is to remove the lower back panel, disconnect the corrugated flexible plastic pipe from the stub that comes from the bottom of the freezer, + pump steam into the stub (gently) using a hand-held steamer (with tube + nozzle). You don't have to empty the freezer or move your food as the door stays closed, and no steam gets into the freezer until the pipe is unblocked. Be sure to unplug the freezer before taking the back off! [There is a fan in this area that could start up without warning]
Check how much of the pipe is blocked by gentle probing with a pencil: the aluminium tray is about 105mm above the bottom of the stub. This measurement is important…
When the pipe is clear, there may still be too much ice in the aluminium tray above (not sure how much is 'too much') if you only created a narrow 'chimney' though the block of ice (likely to get blocked again). You need to widen that chimney by melting more of the ice in the aluminium tray. I use a simple steam nozzle made from an old-fashioned Bic pen with a couple of 1mm holes drilled just below the coloured bung at the end. This directs steam onto the walls of the 'chimney' rather than upwards.
There's no point steaming the walls of the plastic 'stub' pipe, so only use the home-made nozzle when your probe reaches 105mm (i.e. when you have melted all the ice in the plastic stub tube but before your 'chimney' has broken through the block of ice in the aluminium tray). If you judge this right, you'll melt almost all of the ice under a still-frozen top surface: no steam will get into the freezer and your food will stay frozen. With a probe it will be clear when you've broken through the top surface of the ice. When you have done so, it's time to look inside the freezer to see how well you have cleared the aluminium tray.
It's perfectly feasible to get all this done in 30 minutes.
Don't forget to replace the corrugated plastic pipe + valve at the bottom. It stops humid air from going into the freezer and icing up in exactly the area we've just been defrosting.
Take a lot of care with steam jets as they can burn you badly. You should check a first aid website so you know what to do BEFORE it happens.
Some of these tips may be helpful: (1) run the freezer at -18 degrees (the 'warmest' setting) so it's not working so hard. (2) Leave a big gap (>100mm) between the back of the freezer and the wall. (3) Clean the matrix of delicate tubes to the left of the fan whilst you have the back off [a small bottle brush is ideal; remove the fan for better access]. (4) Put something between the middle of the freezer and the wall to prevent the warm air that's being blown out behind the fridge from being sucked into the air intake behind the freezer (there is a baffle built in underneath, but nothing behind. (5) Mount the fan on spacers (with longer screws) so that it's closer to the heat exchanger… this means that a larger area of grille can act as an air intake. (6) Raise the unit off the floor a little to free up the air intake path beneath the freezer.
Apr 23, 2009 | Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Freezers Logo
161 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
washington munene
Level 1 Expert
ray gallant
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
