my saw had this exact same problem, here's how i fixed mine.
okay so here's a schematic of the saw
http://www.toolpartspro.com/image/LS...-Makita-PB.pdf
whether you have the exact same issue as my saw, in order to further
investigate you need to get to the mechanism that locks the saw. To do
this you need to take the turn base (140) off the foot base (156) .
its really not too hard, just a little awkward setting the saw in
different positions to remove the various parts.
Specifically on mine I had issues with the threaded rod (118) not
screwing into the stopper holder (135). You'll see this part when you
flip the saw upside down.
So to remove the turn base(140) from the foot base (156)....
Remove the kerf board (108) and under you will see a big bolt, go ahead
and remove this. Then there are 4 more bolts which take off the guide
rule (117), this what your piece of wood is put against when making the
cut. Once these 5 bolts are out, the turn base can now be separated
from the feet. Now you'll have a better view of the mechanics and see
what is or isn't happening when you screw the handle to lock the miter
position.
Part 136 (turn stopper) is what actually wedges to a pocket in the foot
base which makes the saw lock. when you screw in the handle it
actuates this part. make sure that is happening. I had to take out
the threaded rod (118) and tighten it on a vice and work the stopper
holder (135) deeper onto the threaded rod. use WD 40 to help it a long.
You'll need to take off some other various parts to to get the rod
out. this will be obvious once you have everything turned over.
Now that everything is apart you can blast it with some WD40 or what you
think is best here. I used lithium grease. You'll see its especially
important to lube up the pivot post that the 2 bases center on, (where
the big bolt under the kerf board goes). also the slide plates (153) may
be rusty, they'll fall out when you separate the 2 base plates. clean
those up and spray them and anything else which will help with smooth
movement.
the only important item to check once everything is put back together is
the guide rule. this can be adjusted slightly in or out of square. Get
a nice framing square and make sure your locked in at 90 (or actually 0
degrees on the saw) Sliding the saw the full distance of the cut on
the square is ideal and maybe this was a good time to recalibrate that
movement anyway.
hope this works.
Ben.
