Question about Stanley Garden
How do I change the blade on a Stanley utility knife, 10-788?
Posted by pbrennan380 on
woobie dog
    President:
  • 1,273 Answers
Hi, W/D here.
The blade changing is accomplished by pushing the yellow button and pulling the old blade out. It is reversible. If there is no blade at the ready, there may be more in the body of the knife, which are located behind a swing out panel on the handle. You'll need to push in the yellow button when installing the blade, and once the blade is in, release the button, and moge the blade until it clicks in place.
--W/D--
Posted on Jan 21, 2011
I have a stanley fatmax knife but it doesn't have the small yellow button to help insert a new blade. what can I do?
HI!Kindly pull the button on the end of the knife and then after you remove that you can now put the blade of your knife.
Aug 21, 2011 | Stanley Utility Knife
I have a stanley 99e. i took it apart ti change the blade, without paying attention, and now i can't re-assanble it properly. I can't find any instructions online.
Hi.
See here the Stanley knife disassembly. If you have a 99E there may be an additional plastic part that is not shown in the diagram. The plastic tab is located at the back of the blade.
Jun 02, 2011 | Stanley Utility Knife
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-801 utility knife. How do you change the replaceble blade?
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Nov 26, 2010 | Stanley Garden
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 | Garden
How do you load a new blade?
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part, now slide the yellow part back to reviel the blade folder. Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
Jul 31, 2010 | Stanley Utility Knife
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Garden Logo
262 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
