There is a speed governor on the motor end of the armature (back end of the motor) that may
need replacing. It's one of the few parts still available. on eBay, or mendingshed.com
The grinding could either be the gears in the beater end of the mixer, or the motor bearing on
the back end of the motor.
The gears are available as they are the same as for newer mixers like the K5SS.
The motor end bearing is not available, but I was able to take the bearing out of the motor
bearing plate from a K5SS which is still available, again on eBay or mending shed, and put
it in the motor bearing plate for the K5A. Then you need to soak the felt ring inside the housing
on the back end of the bearing in oil, preferably synthetic like Mobil 1. Also helps to smear
a little moly grease (not out of a tube, not enuf moly content - get some Honda Moly 60, small
tube for $10 at any Honda store) on the shaft when you have it apart.
SOURCE: motor is making noise and grinding sound - only
The green light is probably sparks. Does the light eminate from the rear? If so, it sounds like there is an issue with the control plate. Taking the rear off should hopefully help you spot what is wrong with it. I suspect the board has broken or got stuck.
