Most bluetooth's are the same. You will need to find the button that put's the device into 'discoverable' mode.
There should be buttons on the bluetooth. Some may be hidden so press down on the bluetooth until you locate all the buttons.
Press and hold the 1st button until you hear a beep or the lights begin to flash (when the lights start to flash or change colors, it is in discoverable mode) let go once they begin to respond differently.
Begin your search on your PS3 again.
Repeat these steps if necessary with the other buttons until you get a reaction from the bluetooth.
The default code for most bluetooths are 0000 or 1234. Good luck.
A Bluetooth headset has to be registered, or "paired",
with your PS3 before it can be used.
