The error 245 is a drain pump stall. Take the pump out from the bottom of the machine (2 screws) and clean it out. The resistance between the red and blue, blue and white, and red and white wires should be 16 ohms, if not, replace the pump.If the resistance is ok then clean the drain pump and drain hose to which the pump is connected.Clean it with normal tap water.Then refit it and check.In most of the cases cleaning the pump and hose helps.In some cases the pump has to be replaced/.----------- This will help.Thanks.Helpmech.
