Question about Whirlpool DU1010XTX Builtin Dishwasher
How do you activate the diagnostic mode on a Whirlpool dishwasher model #DU1010XTXQ0/
Posted by prigoni on
Whirlpool quiet partner III unresponsive. "Washing" and "cancel/drain lights glow dimly. Performed reset and diagnostic mode procedures. No response.
Hello Philip,
We are sorry for the frustrations you are experiencing. Please email us at [email protected] with your name, phone number, street address, zip code, model & serial number, date of purchase on the appliance and a brief description of the problem you are experiencing. Thank you.
Best Regards,
Whirlpool Social Care Team
May 20, 2018 | Whirlpool Dishwashers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Whirlpool cabrio is giving a code which is f1,
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Display shows F1 top load cabrio whirlpool washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#*
May 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My diswasher won't work
Kitchenaids have a diagnostic service mode ... but each model can be different on how to activate. The mode is started by sequentially pressing a number of the control buttons repetitively. The particular sequence is usually listed in service technician paperwork within the dishwasher behind the low kick plate in front of the dishwasher.
Or web search "Kitchenaid KUDPO1FL S7 diagnostics" which may help you understand this whole process
Good luck on your troubleshooting
Jan 16, 2018 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool Cabrio F1 trouble code came up 3x recently. Called Whirlpool and they said washer was out of warranty. Once I told tehm about the post they said that it was a Whirlpool "Quality Issue" and would...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%[email protected]#
Jun 12, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washing machine keeps flashing F1?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
Mar 28, 2009 | Whirlpool WTW6400SW Cabrio Washer
Dishwasher will not start
You have a clean light flashing. You need to reset you control. It is activated by a number of different situations. Find the tech sheet for your dishwasher which is normally located under the bottom plate of the dishwasher. If you can not find it give me the model number and I will tell you how to activate the diagnostic test. If you do find it follow the section that says diagnostic test. Then check and makes sure you heater element is operating.
Feb 23, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GU1200xtks0 Blinking Lights
Try pressing heated dry, normal, heated dry, normal keys within 6 seconds. All lights should come on and the machine should enter diagnostic mode. If this does not work remove the 2 screws that hold the toe panel on at the bottom front of the dishwasher, attached inside you will find a tech sheet that tells you how to enter the diagnostic mode. Once you get it in diagnostic mode let it do it's thing, will take about 20 minutes total. At the end the control will be reset. If the fault comes back then troubleshoot according to the tech sheet, or call for service.
Feb 20, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Whirlpool GU2400XTPT6
Check the Tech Sheet you will find it behind the kickplates On many models, this sequence will work: Heated Dry, Normal, Heated Dry, Normal. Press this key sequence within six seconds to activate service mode.let me know if it helps
May 06, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1010XTX Builtin Dishwasher Logo
657 people viewed this question
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
