SOURCE: 50" Samsung DLP TV turns on get sound and picture for 1-2 sec then goes to standby
new bulbs can leak on your pc board if not installed correctly and the fluid starts to short things out... triggers the error message.
remember always check the last thing you did before having problems.
SOURCE: My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
SOURCE: my samsung dlp has no picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
SOURCE: Samsung HLP5085W DLP - lamp
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
SOURCE: Samsung HLS4266 DLP tv.
In all likelihood then the ballast is failing, this is very easy to
replace just a little board attached to the lamp by a couple of wires,
just when you remove lower bottom have a look at the lamp wires and you
wont go far wrong it's available here
http://www.partstore.com/Part/Samsung/Samsung/BP4700037A/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HLS4266WX
The part is in that link highlighted in my last post just click on it
and it will take you to the supplier, if you cant fit it yourself a
technician shouldnt charge more than $100 for the housecall and fitting
unfortunately there are a lot that want $150 just to turn up so if you
could get someone whos practical this is very easy to do.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
