Question about Scubapro Full Face Mask, All
Looking for an adapter that will allow me to use a nonscubapro second stage with this mask. Any ideas.
Posted by makosrule on
saltdragon1
    New Friend:
I use a Cressi reg no problems
Posted on Sep 19, 2011
Acquiring network address ip
This depends on the address you are looking for. The typical address for the adapter is as follows: IP 192.168.1.100 Sub mask 255.255.255.0 Default gateway 192.168.1.1
Oct 15, 2013 | TP-LINK TL-WN321G (812930011748) Wireless...
What do two snow flakes on the left side of the control display mean on a Robert Shaw 9420 thermostat?
The double snowflake means that the second stage cooling is on. (One snowflake indicates first stage cooling.) This gives a greater temperature change in extremely hot conditions with than you could get with a single cooling medium and drier air in your home.
From the patent: A two stage cooling system in which the first stage's cooling affect is transferred to the second stage through direct contact with an oil-like material. The oil-like material is cooled by direct contact with water which has been evaporatively cooled. The oil-like material is then utilized to cool the air stream prior to the second stage evaporative cooling. The use of an oil-like material in the first cooling stage of evaporative cooling allows a relatively dry air stream to be produced so as to fully capitalize upon the evaporative cooling affect of the second stage cooler.
The second stage comes on if your system hasn't reached the desired temperature at the thermostat within a programmed length of time (5 minutes is a usual setting). BTW: Your system also has two stage heating.
I hope this helps.
Jul 07, 2010 | Shaw Robert RS-9420 Thermostat
Poor supply air pressure
3 stage? It sounds like the first stage has a leaking valve, possibly second stage also - this would explain both the high temperature in stage 1 and the poor pressure from the final stage. Take a look at page 6 of the following link. This is the typical intake and outlet valve diagram for each stage. Valves #2 are intake valves, and valves #6 and 7 are discharge valves. They all perform like check valves, each valve allowing air flow in only one direction. It sounds like your valves are leaking between 1st and 2nd stages. Possibly debris in the valves, or valves damaged. Try taking air intake filter off and check for damage to air filter and debris at intake. Also try removing valve plates and check for debris/damaged valves on first and second stages.
http://www.irservicenet.com/filestorage/SCD-749_.pdf
May 05, 2010 | Ingersoll Rand - Rand Type - 30...
The rear-center output from my RX-V1 went out (again). this happened before and I had the unit serviced. It worked fine for a while but dropped out again recently. Any advice?
If the previous repair included the replacing of the final amplification stage (output transistors or output amp-pac), I would look at the speaker itself. Perhaps there is a worn spot in the coil that under a particularly heavy load (loud), shorts out that channel. If not that, then there is the possibility that there is a problem further back in the amp stages that the outputs mask up to a certain point. This is all speculation, because measurements taken inside the unit are required to narrow this down. Can you list the parts replaced the last time? That might give me a few ideas.
Thanks,
Dan
Aug 31, 2009 | Yamaha Audio Players & Recorders
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
35mm slide and negative adapter
First option would be the manufacturer, second would be EBAY for either the part, or a used unit with the part.
Mar 24, 2009 | Canon CanoScan 5000F Flatbed Scanner
How to use safe second with a Scubapro full face mask
Yu only need the octopus adapter kit to put on an octo and you can swap out should your primary reg **** out.
Feb 18, 2009 | Scubapro Full Face Mask, All
Belkin router
A couple of items to check -- these will not fix the issue but may isolate the problem.
Turn all machines on before the test and do not turn off until after
On at least one wired computer that is working and maybe all wireless computers I want you to do the following
Click Start then All Programs then Accessories then Command Prompt
In the window that opens type
ipconfig /all
press enter then record all of the following for each adapter
  • adapter
  • IP address
  • Subnet Mask
  • Default Gateway
  • one or more DNS addresses
The back in the window enter the following command using the default gateway from the wired connection (your router address)
ping (default gateway)
you will either get 4 timeouts -- the connection fails or 4 messages with elapsed times generally measured in ms or milliseconds.
What you are looking for in the above
Good entries base
x.y.x match each other if subnet mask is right
u should be unique for the network
Wired IP address x.y.z.u not 0.0.0.0 may be 192.168.0.u
SubNet Mask ?.?.?.? assuming 255.255.255.0
Default Gateway x.y.z.? not 0.0.0.0 may be 192.168.0.1
DNS addresses ?.?.?.? not 0.0.0.0
where at least one is not zero.
Then wireless entries should be
SubNet Mask same as wired
Default Gateway same as wired
DNS addresses same as wired
If these are wrong there is a configuration error either in the router or wireless adapters depending on how you want your network setup.
each connected adapter wired and each wireless should also
successfully ping the default gateway or router address
If the ipconfig is right and the wired config has successful pings, then every wireless adapter that fails has a wireless config issue.
If you are willing to work through this let me know and reply with information in a comment to this issue.
You may also want to address wireless security
See this response and let me know what you want to do.
Wireless security
Dec 16, 2007 | Computers & Internet
Scubapro Full Face Mask, All Logo
325 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
