Question about Ovens
Hi my framtid 0v10 oven from ikea has ref F11 on screen it no longer works. I used the pyro setting for the first time
Posted by craftysharon on
fino
I have the same problem with the F11. I tried the meat probe thing and still didn't work :(
Posted on Dec 18, 2014
Stephan van der Molen
I've had the same problem. The manual said the F11 errorcode indicates that the meat probe hasn't been inserted properly. Ofcourse I do not use the meatprobe for the pyro cleaning, but I decided to insert it anyway. After insterting it I first took it out and turned the oven on. No effect. Then I turned it off, inserted the meatprobe again and turned it on again WITH the meatprobe inserted and PRESTO! everything worked again!
Posted on Sep 12, 2013
1 Related Answer
Anonymous
SOURCE: My Framtid OV9 bottom oven
Did you solve the problem?
I have the same problem...
Posted on Apr 19, 2011
2answers
We have an unnamed oven serial number framtid ov10 in our new house, the electric circuit shorted out 2 days ago and now the oven wont heat up although the grill fan light and display seem to work?
Unplug or isolate the electric before doing anything.
Check if you need to take the oven out or if you can remove the heating element by unscrewing a few nuts and bolts from within the oven itself .
Elements cost about £10 - £15 in the UK and are available from Ebay or Electrical Parts wholesalers or alternatively from the company itself if you can find a manufacturer , The name shown on the product may just be a Logo brand name but manufactured by a larger company for a specific store.
Jan 09, 2018 • Ovens
When on fan symbol only and with a temperature set manually, the oven will not heat. The bottom and top heating elements will heat up seperately on other settings
My oven is DOP705X. It had the same problem on two occasions. First time it was simply the fan element. Second time I thought it was the element so replaced it again, but no fix. Turns out it was the relay for the fan element, it had got sooty and black. A quick clean of the contacts with emery paper and it was all working again. If the relay needs replacing, a new one is £2.88 from RS Components, but replacing it will require a spot of skillful soldering.
Missing instruction manual for IKEA Whirlpool oven FC SM6
After a powerbrake the IKEA Whirlpooloven doesn´t work, the display just says STOP and nothing works, not even the light inside the oven. This always happens after a powerbrake and usually I can fix it after some time pressing different buttons but not today. Suggestions?
Dec 17, 2009 • Ovens
Stove flashed F11 and then locked the oven door
HI, this is control failure. the logic chip set is damaged. this is causing these erratic commands and the unauthorized locking of the oven door. you will need ot replace the control in this case.(EOC/clock)
5helpful
How do I set the clock on an IKEA oven?
Hold down the 'ok' button and it should be fairly self-explanatory from there.
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
