Best to buy this as an assembly. remove the drivers door panel behind the door is the window motor and regulator assembly. unbolt the regulator from the glass and remove the glass or prop the glass in the up position unbolt the motor and remove the assembly from the door and reinstall the assembly be carefull to position the nuts for the glass and make sure the pads that protect the glass are in place dont over tighten the nuts on the glass part or you will explode the glass
