Question about Sharp AR-5316 Advanced Digital Imager Copier
I NEED A SHARP SERVICES CENTRE ADDRES IN LAGOS NIGERIA FOR MY COPIER MACHINE
Anonymous
    New Friend:
I need the address of where i can buy sharp photocopier machine AR 5316 E.
Posted on Oct 05, 2011
1helpful
There was sudden high voltage supplied to the apartment and my Avantixx 7 VarioPerfect could not start. What can I do?
Hi Adewale,
Unfortunately you need to contact Bosch customer service. You shouldn't try to solve by your own, you can void your warranty.
Philips office lagos nigeria
Try ringing phone first see if this has support department
PHILIPS ELECTRONICS
Address
Akin adeola Street, Victoria Island, Lagos, Nigeria
Phone
234-01-266 6118
- See more at: http://www.businesslist.com.ng/company/138122/philips-electronics#sthash.u7E7byi3.dpuf
1helpful
Where can i purchase a brother printer and consumables in Nigeria
If you take a look at Brother's store locator, you can ifnd only these two Brother dealers in Nigeria (Lagos).
Maycom Technologies Limited +002 341 740 3127/ 080 283 24770/ 070 280 91369 +002 341 271 1439 54, Ogunlana Drive, Surulere, Lagos
The Copy Cat (Nigeria) Ltd. +234 182 17189/ +234 806 0752052 +234 832 32162 1A Talabi Street Ikeja, Lagos
The MFC-7420 is no longer manufactured, so you may only be able to purchase that model used. But these two locations should have supplies and similar models.
2helpful
Help destroy my Samsung SGH-L760 Phone?IMEI:353329/02/205862/8
HO MANDATO UN MSG E SI è BLOCCATO SI è SPENTO è NON MI PRENDE PIù IL PIN SI ACCENDE MA NON LEGGE IL PIN COME SI PUò SBLOCCARE SENZA PERDERE TUTTI DI DATI LA RUBBRICA E LE FOTO?
Where to buy Macbook power pack in Nigeria
The Orchard
Shop 3
The Civic Centre
Ozumba Mbadiwe Road
Superior Equipment Limited
285b Corporation Drive,
Dolphin Estate, Ikoyi, Lagos
Nigeria
01-4614048/58 07028064108-9
SANSUI HD LCD 42 INCHES screen is broken and needs replacement ,
You're better off just replacing the TV because of cost. If it is still under warranty why not contact the dealer you bought it from for an authorized service center location.
1helpful
2answers
THE KEYS ON SHARP AR-5316E X REFUSED TO WORK
I dont have the exact manually for this machine although most of the sharp error codes are consistant for most newer models. L1 refers to the scanner area of the machine. The scanner is a part that looks at your original by shinning a light across the page and tranfering that to the machine with mirrors. If you lift the lid and push the print button, you will see it under the glass. Something may be blocking its movement if you hear an unusually noise when trying to print. If no noise it could be a sensor, motor, or a circuit board.
37helpful
7answers
Sharp AR-5127, the error code U2-40
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
2answers
My sharp sf 2022 machine, i need solution
mr engineer please check the drum mark sensor and clean it and also check the check the toner motor connector and do this program    c interrupt 0 interrupt ,44 copy key 07 copy key after stoping the machine off and then on but first clean drum unit maintenance code is 20 then copy key and then three times ca ca ca
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ekse
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
