Question about Motorola Mobility RAZR V3
How to reset unlock code motorola v3 - Motorola Mobility RAZR V3
Posted by samjedturon on
mikeharis
    Novelist:
  • 250 Answers
You Can Reset Your Motorola V3. Call Your Network Provider To Ask Your Motorola Unlock Code. But your Network Provider Takes Time To Give You Unlock Code.
If You Want Your Imei Unlock Code Instantly. Buy Motorola Imei Unlock Code From Third Party. Many Sites Available Online To Provide Imei Unlock Code.
I Hope This Will Help You.
Thank's
Posted on Feb 14, 2012
RONALD CARTER JR
  • 438 Answers
Hi samiedturon use *22890 this will rest the lock code to your phone it will make it the last four digits of your phone number.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Posted on Jan 20, 2011
monette wee
    Champion:
  • 241 Answers
You may have to purchase the Motorola V3 unlock code from a MOTOROLA UNLOCK CODE website to permanently unlock you phone. Once your phone is unlocked, you don't have to stick to one network, your phone should be 100% SIM lock free.
Posted on Feb 08, 2011
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: code to unlock my motorola razer v3 phone
i do not know the code. but if you need it badly you can buy it on ebay for about 1 dollar
Posted on Apr 01, 2008
tbirdfan1
Michael Thomas
  • 3053 Answers
SOURCE: Unlocking my motorola v3
hi there
normally you can axcess your codes by entering the lasr 4 of the phone # and than uncheck the security box ok hope this helps if not i would get in touch with motorola ... regards mike
Posted on Feb 16, 2009
Anonymous
SOURCE: Overriding blocked features on a found Motorola v3
Don't bother trying to use a device that was likely reported as lost or stolen; more likely than not you wouldn't be able to. In good conscience you wouldn't want to use a device anyway that someone else would have to pay for, right? Eventually the phone will be rendered inactive, in which case you might be able to activate it on your own account, unless it is on a "negative file," in which case it's as good as a paperweight. Unless you sell it to a recycling program online, such as a so-called "buyback" program.
Posted on May 30, 2009
Anonymous
  • 206 Answers
SOURCE: no. i need to unlock my motorola razor v3 for
My friend gave me a razor to unlock last night that he just bought from a long time user on Cingular network. Since I unlocked without trouble I thought I would help someone out. Basically you need to flash one software into your phone, then you need to run another program and unlock it. Here is how I did it. Download and install EMULE, a free program. Run EMULE and select edonkey network only and forget KAD network during setup. Don't upload with emule in chunks as I believe it takes more processing power from the PC. Now run EMULE and click Connect. After it connects search for a program called P2K.EASY.TOOL. It will be around 6.2MB file. Extract all the files and look for a file called P2K_Easy_Tool_v39 and extract this also. Next, you need to get the program called RSD Lite 3.0. Again get this file by searching emule for this and downloading. Then install the program by double clicking on .msi or right click and click install. Now get the program Motorola_Unlocker_2005.zip. This can be found quicker at themotoguide.com/unlocking.php. This file may not be necessary or this step! CHARGE the phone to full charge. I forgot two more file are needed! You'll need to USB drivers for the phone. The ones I used were v3_drivers.exe (search yahoo) and always click continue anyways. Finally, you will need bl_826-828_to_07d0_ for_V3_by_Archy.V2.shx (no space between 07d0_for_) and this file can be gotten at themotoguide.com/unlocking.php. If you attempt to communicate with the phone it may want to install drivers and you may have to do the operation again. When installing drivers, just specify the folder where you extracted USB drivers. Now lets get started. Plug the phone into USB cable and turn on. Run the program called RSD Lite 3.0 and then it should say connected and show your phones IMEI #. If not, you could restart phone, but press # and * with one hand then start up. Now it should say in RSD LIte 3.0 something different. You can leave it like that or restart phone and then you should definitely see IMEI #. Now click on FILE in RSD Lite 3.0 and search for the file bl_826-828_to_07d0_for_V3_by_Archy.V2.sh… and click OK. Now lets downgrade the bootloader, click START. Wait tell it is done and finished at 100%. Don't even mess with the computer during this time or any cables. Turn phone off and hold down * and # on phone again and turn phone on into Flash mode again. It should say 07d0 now or be a blank screen, which is fine. Now run the program Motorola_Unlocker_2005, click send to phone. It will do something and your phone will reboot. If it is unlocked then you are done. If it didn't work as mine didn't with this step then turn phone off for third time. Again boot up in flash mode by holding down both * and # and turn on with other hand. It will be in flash mode with black screen. Now run the program called P2K_Easy_Tool_v39.exe and there is one other file in this folder called winscard.dll. Click on LOCKS and then select your phone model. Now select Unlock SP. Click on DO SELECTED JOBS. It should show the status above and will do some work, then reboot phone do some more work and power off, I remember. That is it turn it on and you are done. Lets sum this up on what is needed. EMULE, P2K.EASY.TOOL, RSD Lite 3.0, Motorola_Unlocker_2005.zip, bl_826-828_to_07d0_ for_V3_by_Archy.V2.shx. You could probably skip the Motorola_Unlocker_2005.zip step. If for some reason you destroy your phone! You have a 80% chance of recovering it by going to www.themotoguide.com/downloadfirmware.ph… and getting one of these three files, extracting it. Then flash it into your phone with RSD LITE 3.0. Do not do any of these steps if it is illegal in your country or you don't deserve to use your phone yet or buy talk time from a network!!
http://www.themotoguide.com/unlocking.ph…
Hoped it Help.....
Posted on Aug 01, 2009
ahker1124
SOURCE: need pin code to unlock motorola v3 razor please
I HOPE I CAN ANSWER YOU BECAUSE I MET THE SAME PROBLEM WITH YOU
Posted on Mar 07, 2011
Need to unlock my motorola phone v3
Hi do you want codes to unlock v3 or v360? just make a try with mobileunlocksolutions and get unlock code from them and get your mobile unlocked..
Jul 30, 2011 | Motorola Mobility V360 Cellular Phone
I need to master reset my Motorola v3. I don't know the code to put in.
Here are a few of the most used Tech Codes for the v3
1998072 - To unlock almost all Motorola mobile phone
*#06# - Displays the IMEI number of your phone
*#403# - Displays the manufacturing details of your mobile phone
*#301# - To Test the function of your phone keys.
*#300# - Displays the details about your phone's Hardware and software version
*#311 -Master reset - To revert back to factory settings.
*7 - To unlock your keypad
Feb 19, 2011 | Motorola Mobility RAZR V3
What is the master reset/clear code for the motorola razr v3?
Feb 09, 2011 | Motorola Mobility RAZR V3
How to unblock & reset subsidy code on
for unlock your phone you can try subsidy code here http://www.superunlockcodes.com/motorola-motorazr-maxx-v3 for getting codes you need to specify the country were you want to unlock from
Mar 10, 2010 | Motorola Mobility RAZR V3
How can i reset my security code?motorola v3
Changing a Code, PIN, or Password Motorola V3
Your phone’s 4-digit unlock code is originally set to 1234, and the 6-digit security code is originally set to 000000.
Your service provider may reset these codes before you receive your phone.
. The unlock code must contain 4 digits, and the security code must contain 6 digits.
One trick I know: When changing the code, when it asks for the old password, press the "menu" button first, then enter 000000 and that may work also.
Feb 01, 2010 | Motorola Mobility RAZR V3
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
Unlock code
http://ezinearticles.com/?Motorola-Razr-V3-Unlock-Code-Input---How-To-Unlock-Motorola-V3-Razr-Phone-by-Subsidy-Unlock-Code&id=731904
This link will help you with unlocking.
Mar 27, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Unlock motorola v3
if you have not changed the security code, press menu key , when the phone prompts you for the security code then enter 000000 now you can master clear or reset all codes back to the default settings or take it to a mobile service center and have them reset it for you.
Feb 17, 2008 | Motorola Mobility RAZR V3
Phone lock & security codes for RAZR V3
see buddy what u have to do is firstly u have to put worng code 4-5 times than it will ask for the PUK code which u have to put in after that. it will reset the password ,,,, if uu have allready followed the procedure than u can consult withany local vendor out there.
Oct 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
576 people viewed this question
Top Motorola Mobility Cell Phones Experts
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
