Question about Jabra Stone Bluetooth Headset
I cant pair my jabra bluetooth to my evo! - Jabra Stone Bluetooth Headset
Anonymous
First, put the headset into pairing mode. To do this, remove it from the Stone charger and press and hold the answer/end button until the lights flash four times slowly - this indicates that the unit is off. Then, press and hold the answer/end button again - you'll soon start to see lights flash - hold the button until the green light is on steady and the blue light is flashing. This is pairing mode. Now your Evo should be able to "find" the Stone to pair with it from within the Bluetooth menu on the phone.
Posted on Jan 20, 2011
  • Anonymous Jan 20, 2011
    If you continue to have any issues, call Jabra Product Support at 800-327-2230 8am to 8pm EST.
  • leestigul
    leestigul Jan 11, 2012
    I am so in love with you for this!! I couldn't figure it out and the instructions said NADA!!
HappyMomo2
    New Friend:
This also worked for the IPhone 4. Thanks.
Posted on Aug 13, 2011
2 Related Answers
Anonymous
SOURCE: how do i pair my jabra w/my phone. cant find
hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
Posted on Sep 09, 2009
award462
Anthony Ward
  • 397 Answers
SOURCE: how do i pair a jabra bluetooth with ps3
Refer here:
http://www.fixya.com/TipsAndTricks/preview.aspx?thid=5009279
Posted on Jun 02, 2010
Cant pair my iPhone with jabra sp5050
forget the headset
turn bluetooth off
turn the headset device off
reboot phone.
try again
Mar 04, 2014 | Jabra A320s Bluetooth Wireless Adapter
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
My phone can't find the headset. HTC EVO
Make sure you have your bluetooth device in pairing mode to do this you usually hold the power button down while turning on the blue tooth device,then there should be a light that stays on ,now that u are in pairing mode you need to enter a pairing code most bluetooth manufacturers use a 4 digit pin pairing code they are as follows 0000,1234,9999,or 1111, i hope this helps.
Mar 23, 2011 | Jabra BT4051 Bluetooth Headset
HTC evo will not pair w my jabra stone, says incorrect pass code, how do I re enter the pass code?
By putting the blue tooth device in discovery mode it will reset it then your will have to enter the manufactures factory pin pairing code,Most blue tooth manufactures use a 4 digit pin pairing code,they are as follows0000,1234,1111,or 9999 this should be the code you are looking for i hope this helps
Feb 22, 2011 | Jabra BT350 Bluetooth Headset Headset
Cant connect my Jabra BCE OTE4 with my LG 8300 cell phone...help
default PIN is 0000... be sure to turn on BT on your phone first, then power on your jabra... your phone should ask to pair to the jabra and then you enter the 0000
Aug 21, 2010 | Jabra Bluetooth Headset with Adjustable...
How do i pair my jabra w/my phone. cant find
Sep 07, 2009 | Jabra BT125 Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
Jabra Stone Bluetooth Headset Logo
1,279 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Mosaub Al Masri
Mosaub Al Masri
Ekse
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
