Question about KitchenAid Architect ® Series II KBFC42FTS Stainless Steel
Is it possible to replace the handles on the KitchenAid 42" built-in stainless french door refrigerator (KBFC42FTS) with different handles? Ideally handles that look more like the handles on the Pro Line appliances?
Posted by gcamp94 on
dennis dodge
  • 1,891 Answers
Most the handles will inter change . you will need the model # of the other frig in order to get the ones you like . but keep in mind they are not inexpensive . I looked up one of these pt # 2316868 stainless handle and are sittind down! they are $ 101.93 each . . and you need 3 .. hope this helps mm feed back pls
Posted on Jan 20, 2011
Why doesThe light does not go on when the left door opens and neither do any of the settings light up?
bad switch. or the wire has come off the switch. You have an open circuit. this means electricity is not flowing all through the circuit. it could be a switch, a bulb or a fuse. Start with the easy stuff. find the switch and push it in an out. many new refrigerators will shut off the fan if the door is open. if the fan goes off check the light bulb.
Oct 10, 2014 | KitchenAid KBFC42FTS 42" Bottom Mount...
What does the code PO mean on my kitchenaid refrigerator?
On my KitchenAid, KRSC503ESS, to clear the PO (Power Out) message, press the 'measured fill' button on the front panel for 2-3 seconds. It is right below the word 'confirm' on the display. The technician told me that you need to confirm that you know the power went out so you don't eat any refrozen food. There is absolutely no information about this in the user manual or on the KitchenAid site
Sep 28, 2014 | KitchenAid Kitchen Aid 22.6 Cu. Ft....
How to fix kitchenaid kbfc42fts bottom freezer builds up ice and leaks on floor
The drain line is clogged go around the back of machine take off back cover and you will see a drain line coming through the floor and at the end of it is a rubber grommet.The rubber grommet is clogged up just take it off and throw it out and then turn off machine for 24 hrs with doors open to melt out all the ice
Aug 08, 2014 | KitchenAid KBFC42FTS 42" Bottom Mount...
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
How to remove Electrolux Icon refrigerator door handles
look real close as the screws may not be hex but tec special screws that require a tec bit set ( available from a good tool shop)
you mention metric sizes for the hex but the screws may be imperial and not metric and that may be the difference
Mar 07, 2017 | Electrolux Refrigerators
Left door plastic locking peice broke
Here is the complete parts list for that unit. You can order directly from the supplier and all parts come with a 365 day, any part, any reason return policy.
Dec 01, 2012 | KitchenAid Architect KBFA25ERSS Stainless...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
Whirlpool stainless french door refrig...need to take handle off bottom freezer door so I can move it out of house. Is this possible without taking off the whole door?
it is much better to remove the complete door instead of handle . there are 4 screws inside that will release the complete door . if your want to do the handle use a credit card and insert it between the handle and door to release . but if stainless it some times leaves marks on door . i always remove the doors as one door is ever and i mean very costly.. mm hope this helps mm feed back pls ..
Nov 08, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Feb 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
KitchenAid Architect ® Series II KBFC42FTS Stainless Steel Logo
278 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
