Linksys Wireless-G Broadband Router Logo
Posted on Jan 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My linksys wireless = g has stopped working wirelessly it still works by ethernet conection but can not be found on any network search? it has worked for the last 3 years with no real problem but it just stopped sending a wireless signal
Level 3:
  • Linksys Master 7,733 Answers
  • Posted on Jan 20, 2011
Linksys Master
Level 3:
Answers
7733
Questions
0
Helped
1863177
Points
21487
There is a great article at Working with Windows Wireless Networks and General Router Setup.
If you need more help post back! Thumbs and testimonial are welcome!
I got inernet conection, but when computer is conected thru router internet does not work
If your OS is Windows here is a great article on Working with Widows Wireless Networks and can help you to configure all Windows OS Wireless networks.
I can not conect to my linksys wireless router with my dell inspiron laptop I can conect to any other wireless network but the linksys help please?
Can you provide more information about this issue.
1. Is the wireless card enabled on your laptop ?
2. Does it try to search for available network ?
3. Do you get any error message ?
FixYa Team
1helpful
Can't find when searched for
It is probably time for a replacement. We've found that we routinly replace linksys wireless routers after about 1 year or service usually no more than 2 before they die.
Usually the wifi section slows, then become intermittant and finally stops working.
About the only thing you can do is do a hard reset. This will reset it back to factory defaults so you have to setup everythign again. Push and hold the reset button for about 10-20 seconds. That will then restore it to the way you had it new from the store. Having said that usually this will at best temporally fix it or do nothing. It is worth a try but don't forget a new router is maybe $40 so don't get too worried about fixing it.
2answers
Linksys wrt160n will not broadcast the internet wireless or ethernet it will however broadcast a connection to the router not the internet. I have tried to re-set it, power down, nothing works. I have not...
Your Linksys WRT160N is a router that can be accessed via CAT-5 cables and wirelessly. You must configure the router though, for wireless use. If this is not configured or not configured correctly, then you may have problems using it wirelessly. Laptop computers usually use the 802.11g mode, not the 802.11n, at 54MB or with the right NIC in a desktop you can get 108MB. If it was working then quit without your doing anything, you may have to replace the router, but I doubt it.
Cant get the Linksys to find the Optus DSL network
do you have security enabled on the wireless router?
if so, disable to security and see if you can connect.
if it works, check if you set the router security to use WPA2- it is possible that your laptop/wireless card doesn't support it- try to use WPA instead
When I connect the wrt160n in the pc it says network cable unplug
Check the Ethernet adapter status under network adapters in devicemanager.
right click my computer-properties-hardware tab-device manager-network adapter.etherrnet should be green
1helpful
I have a printer attached via USB to a wi-fi connected desktop in a WGR614g network which supports an additional ethernet-connected desktop and two wi-fi laptops. Can I make the printer wi-fi accessible...
Do a search engine hunt for a "WIRELESS PRINT SERVER" and you'll bring up a Netgear WGPS606 for about $60-80 or a Linksys for $36-150 (the same one :-)).
The Netgear has 2 USB A ports and 4 ethernet ports. You plug in your printer, activate the wireless part to receive a signal and you have a networked USB printer.
I assume the Linksys works exactly the same way, except it may not have the additonal 4-port ethernet switch.
Carl
Wireless ir conected, but don't works
My name is ArmyMason, I have a suggestion for you. In Internet Explorer click on file and see if Work offline is checked. If it is unchecked it and try again. If this solution doesnt work might I suggest using our premium service or live chat.
Thanks,
ArmyMason
1helpful
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
The lights are on but the linksys is not working
Certainly if the conection directly from the router to the computer is not working then the wireless won't work. So that's where I'd start. Cable connections could be an issue. The connection without the router works I assume. Make sure you are connected correctly. You need ethernet cabling to the ethernet, networking connections to and from the internet device to the computer and into and out of the router. When you get the direct router connections working you can solve your wireless problems.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
