Question about Microsoft Xbox 360 Controller
MY CONTROLLER WONT CNNCT TO MY XBOX EVEN WEN I SYNC IT . ITS BRAND NEW.
Posted by ultimate1087 on
Sean Blundy
    Sergeant:
    Champion:
  • 289 Answers
You might have to replace the batteries in the controller, as if the battery life is low the controller will have issues syncing to the xbox 360. Just in cause, To sync the controller to the xbox 360, you must turn on the controller using the xbox guide button and then press the Wireless Sync button right next to the Controller Charging Port. Then you must press the sync button on the xbox 360. You must do this semi-quickly, or the sync process will not complete.
Lastly, You also might have a faulty controller, I suggest you go back to the store you got it from and see if they will replace the faulty controller.
Posted on Jan 20, 2011
I bought an xtra x box 360 controller and it wont work the unit is all brand new. the one that came with box console works but the other one wont. people say i have to sync it and i dont know were the...
You will see the syn is a very small button on the top of your controller. There will also be a sync button (with same emblem next to it) under the little flip cover on the front on the bottom or the right depending on how you xbox is setting. Press the xbox first then immediately press it on the controller the ring should flash then circle and you controller should be working. Note this may take couple tries they can be tricky some times.
Were is the sync button on the brand new xbox 360
The sync button on the console is right next to the memory unit b slot on the front of the xbox 360. The sync button on the 360 controller is on the top between the two bumper buttons.
I can't get my wireless controller to sync to the console. I just put brand new batteries in it. The green light just blinks. I can't even power the controller off. I have to remove the battery pack to...
hi, have you tried pressing the sink button on the xbox as well.
when you turn the xbox on wait for it to come on all the way then press the little round white button on the xbox this is down and to the left of the start button then press the sync button on the control this should then pair them up and get it working for you
When i put my hard drive in it stays at the xbox 360 start up screen (xbox globe) and it stays there for a wile then wen it loads up it says that my hard drive is connected i thought it was the xbox and...
Try this when you have the xbox off hold the white sync button on the controller itself while holding the sync button press the center x box button to power on the xbox do not let go of the sync button until the xbox boots up it should take care of the bad install which it sounds like you have
Game loads okay but controller does not work. controller is brand new. lights work on controller but can not ply any games
If the controller is brand new, you need to Sync it with your XBox 360.
Turn on your 360 using the button on the console.
Turn on the controller by holding the X button in the middle.
With both on, click the SYNC button on the xbox 360.
Then click the SYNC button on the Controller.
The green ring around both should flash a few times, then the upper left quadrant should light up on both meaning it's Sync'd.
Enjoy.
2helpful
Xbox 360 guitar wont work
That is a syncing Issue, Try this, it may take a few tries. Press the Sync button on the Xbox 360. Then press and Hold the sync button on you Guitar for 1 Second. The Xbox and Guitar Should Sync.
4answers
My Xbox 360 wont sync any of my wireless controllers and the powe
if your wireless controllers wont sync to your xbox, it could be one of 2 things.
assuming your batteries are fully charged, and that you're using a certified xbox controller, it could be that the controller itself. it is really rare that the wireless receiver inside the xbox itself, goes out, but soemtimes, it happens.
the easiest thing or you to do would be to either pick up an after market controller, or another certified controller, and see if they'll work. if you try other controllers, and they STILL dont work, verify that your system settings are correct, or are set to default, and make sure that your xbox isnt sitting close to something that could be interfering with the signal....like a wireless router for example
if this doesnt work, then it's a problem with the xbox, and you should send it back to the service repair center.
69helpful
12answers
Xbox 360 won't recognize my controller!
If your controller is just blinking you must press the small button on your xbox and at the same time press the small button on the back of your xbox controller and the xbox will pick controller signal.
Microsoft Xbox 360 Controller Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Joseph Murphy
Joseph Murphy
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
