SOURCE: lexmark 4300
Are you on Vista or XP operating system ?
Lexmark web site has updated drivers for both.
I am using a p4350 on vista, I downloaded the vista driver from Lexmark, it works but Imaging studio doesn't seem to.
However use 'Paint' to scan and don't forget to select or make the P4300 the default printer.
Jim
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
SOURCE: HP All-in-One Can't scan without printing
There is an OCR reader in the programs included with the install disk. This OCR will break down your entire document for editing. If you don't have the disk, it very simple to get all the software from the site.
SOURCE: Canon pixma mp 190 won't scan / copy and printing works!
I also have a newly purchased MP 190 that prints but will not scan at all have also tried reinstalling software.
anyone help me?? :(
