Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
Posted on Jan 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. My Belkin wireless pre-n has no power, no lights. Tried different power adapter and reset, but no lights. Mark
Christopher Thrash
Level 3:
  • Master 425 Answers
  • Posted on Jan 20, 2011
Christopher Thrash
Master
Level 3:
Answers
425
Questions
Helped
107597
Points
1354
If you cant get power to it try another power adapter with same amps if that dont work its most likely shot its most likely a diode if you can solder you can take it apart and with ohm meter figure out the one that is burnt most likely be better off purchasing one,
Testimonial: "Good plan! Thanks!"
After resetting my Belkin Wireless Pre-N router I click submit to login belkin router I get
Still not reset. Hold the reset till it cycles. A simple push only restarts it. You have to hold it in while power is on.
1helpful
Hi, I have a belkin surf F7D2301 wireless router that has been performing wonderfully for about 6 months until the other day when it stopped working out of the blue. No power lights are on and it does not...
Before contacting Belkin to obtain a replacement of the unit, I'd suggest attempting to locate a different AC adapter for your router.
You never know, it may be bad and your router could be fine.
If you can't locate one, or the one you found didn't work, contact Belkin for a replacement.
http://www.belkin.com/contactus/
1helpful
I have a belkin N wireless router,got it 15days back.few days back its not showing any connection waht might the problems,tried connecting it to different power plugs.
The unit maybe faulty. Connecting different power plugs (adapters) may cause the Belkin to fail if the power adapters are not the correct voltage and polarity.
My belkins wireless light wont come on anymore?
* try connecting ur belkin router to different power socket * try with different power adapter * or else press the reset key for more than 1 min while holding the reset unplug the router power cable and plug it back again 3 times.--- while holding the reset u shouldnt release the reset while u unplug and replug. the interval between each unplug and replug should be 15 seconds. * then release the reset then unplug the power cable and plug it back * it has to work or else replace it with the belkin tech support
1helpful
Belkin Wireless G Gaming Adapter not acquiring IP
when you insert your adapter in the computer do you get found new hardware balloon if not then try with a different computer if still doesn`t then your adapter has gone faulty.if you do get the balloon then i would suggest you to install the adapter with latest driver.take care.
1helpful
2answers
Is belkin router f5d8230-4 a g or n? i need tyhis
It is a PRE-N router, which means:
When you see a “pre-n” product, it is one designed based on the future “n.”
standard, but is not a standard. It will generally only work with that companies devices, which means if you buy brand XYZ’s wireless router, you will also need to buy brand XYZ’s wireless networking adapters for all of your computers.
Interoperability between pre-n and non pre-n devices can be difficult and even if you get it to work, you don’t gain anything unless everything is pre-n.
Belkin turns off and on when i type ip address to get in to setti
Which Belkin device?
A two-port Kvm (Keyboard/Video/Mouse) switcher?
A Belkin PCMCIA card?
A Belkin USB adapter?
A Belkin router?
My belkin router wont light up?
  1. Try plugging the router to a different power outlet.
  2. Reset the router.
  3. Check the power adapter specification of your router and if you have another power adapter that has the same specification then try that power adapter to your router.
  4. If using another power adapter and your router will not power on still, it is possible that your router is faulty already.
Hope this helps!
Belkin n wireless usb speed problem
For your connection to reach 300 MBps, not only must your Belkin WiFi USB adapter be an N, so must your Access Point/Router also be N capable.  Additionally, your Internet/DSL connection would also be a limiting factor on your Internet Connection speed.
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
