Question about HP (400745-001) Sound Card
Note that the microphone is not listed individually in Device Manager because it works through your sound card. Perform the steps in the following sections in order, and then test to determine if your issue is resolved after each section.
NOTE: The microphone should be selected as the recording device in the Volume Control tool(sndvol32.exe).
To verify this, follow these steps:
Click Start, and then click Run.
All the properties listed on the Playback section of the Volume control are independet of the recording settings. So you could record through the microphone by selecting it on the recording section, and mute it on the playback section. Then, you could record sound, but wouldn't hear it through the speakers while you are recording.
Check Your HardwareIf your microphone has never worked, or if it has stopped working, first check the physical connection of the microphone. Verify that it is firmly plugged into the microphone port instead of the headphone or speaker port. If you are not sure which port is correct, you can check the sound card to see if it is marked (sometimes with a picture of a microphone), you can use a process of elimination, check the documentation that came with your hardware, or contact the hardware manufacturer.
Sound Recorder
If you cannot record a .wav file after you follow the steps in the previous section, there may be a problem with your microphone property settings. To check these settings:
Posted on Jan 24, 2011
Mar 04, 2011 | Samsung Cell Phones
Sep 02, 2010 | ASUS P527 Smartphone
Jul 28, 2010 | Logitech QuickCam Express Web Camera
Mar 22, 2010 | Microsoft LifeCam VX-3000 Web Camera
Jan 19, 2010 | GE EasyCam Webcam
Jan 11, 2010 | Logitech QuickCam Deluxe for Notebooks
Dec 28, 2009 | Microsoft Computers & Internet
Dec 22, 2009 | Yahoo Messenger
Dec 10, 2009 | Microsoft LifeCam VX-5500 Webcam
Nov 16, 2009 | Microsoft LifeCam VX-1000 Webcam
Dec 23, 2010 | HP (400745-001) Sound Card
Nov 25, 2010 | HP (400745-001) Sound Card
239 people viewed this question
