Question about Brother HL-2040 Laser Printer
My printer says it is offline but the status monitor at the bottom of the screen says its ready... but will not print.. whats going on?
Anonymous
I've been suffering the same problem, but I think I havefound a solution. I have a MFC9320CW. It was showing 'ready' on the computer,but 'offline' on the Status Monitor.
My printer is set up to go to sleep after 5mins. I thought this was a problem,as initially it looked like it was in a coma, but it turns out it's ok.
I installed the software on my desktop (windows7) and after a bit of time thestatus monitor turned from offline to sleep. From here you can go into the(CC3) ControlCentre3 ->Device settings -> Remote setup and enter thepassword = access. Please note if the status monitor is showing offline youwill get an error message. A new window opens up. I went down to -> WLAN-> TCP/IP and then I changed the IP address, subnet mask and IP gatewaysettings, I also changed IPv6 to enabled. I applied these settings and then theprinter appeared to work as I expected it to.
I got the IP address etc from the printout I got when I initially set up theprinter.
I've been able to scan through the CC3 at my desktop; from the printer and thescan has gone to the desktop; and also from Adobe Acrobat8 at my desktop. I then set up a laptop (vista), first off I uninstalled allthe Brother software I had put on it as I'd managed to put the software onseveral times. When I installed the new software I chose the option MFL-Prowithout paperport11. When the status monitor opened and it was in the sleepmode I went to the CC3 -> Device settings -> WLAN and found all thesettings had been adjusted to those I had set for the printer at the desktop. I've now gone through installing it on a second laptop (XP).Again uninstalled previous attempts, then reinstalled MFL-Pro without paperport11 and this too is now working. So, if need be uninstall then install the software again.When you get the status monitor showing sleep/ready go into the ControlCentre3,change the settings as above, then all should be well. Since changing these settings the status monitor hasn't yetgone back to offline. I'd struggled for days before I got it sorted; the onlinehelp hadn't been much help. I hope this helps.
Posted on Mar 27, 2011
  • Anonymous Mar 27, 2011
    Ok, great joy turned to sadness after about 3 hrs when the dreaded offline status appeared. Now can't change it. I figure I'm going to have to install it everytime I want to use it :(
Printer offline wont print cant get back online
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
Printer offline
Brother Printer Offline Windows 10 usually relates to a printhead problem and an error message shown will flash on the Screen. lights will keep on flashing as a sign of this Offline windows 10. Caused by some foreign trash inside the rollers of a printer or due to paper jam in Printer and many more PC causes.
If the problem continues, check this blog or call Brother Printer support services or a Printer Support to stop more printer damage.
The point that fixes Brother Printer Offline Windows 10 Easily:-
1. Check The Network Connection Of Your Brother Printer, Due to poor connection, your Brother printer can display offline on the screen. So, check the connection first and make sure the devices are properly connected.
2. Test The Printing Status-Power off the Printer and then power it on back, Press Windows + I keys simultaneously on your keyboard, Click on Devices button.
3. Update Printer Driver, Offline brother printer issue may confront during a print job. So, update your printer driver immediately for making your offline printer online and print hassle-freely. You can visit the official site of Brother Printer and look for the most recent driver. Select a driver that is compatible with your Windows operating system.
If Brother Printer Offline Windows 10 is not resolved, this might mean there's waste within the printer's inside. Call the customer services our check this Blog for a full solution.
May 12, 2013 | Office Equipment & Supplies
The Brother MFC-7840W printer was installed on a USB connection. The printer worked the previous week albeit not for all applications but at least for the Vista word program. Now it doesn't respond to...
Hi there!
You can check if the usb cable is connected directly & securely from printer to your computer. Once it's verified. The display of your printer should show the date/time.
Since the printer is displaying offline you can open Control Panel, go to Printers folder right click on the printer icon and select 'Use printer online' If you have pending documents right click on the printer icon and click on cancel documents.
Try checking for a duplicate copy of your printer driver or check which printer driver is selected as the default and has the status ready.
Right click on the printer driver that has a Ready status click on printing preferences and click on print a test page.
Hope this helps! Vikroks
Mar 22, 2011 | Brother MFC 7840W Printer
My HP officejet 4315 v All-in One is set as my default but the status shows offline, how do I turn the status to ready and to be able to print from the computer?
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Feb 06, 2011 | HP Officejet 4315 All-in-One Printer
LaserJet 3600n Printer: my HP LaserJet 3600 displays status READY yet my p...
from your printers folder go to the tool bar and open "tools" there is an option in the drop down menu thats "use printer off line" make sure that this is not checked.i have had this problem often when the printer gets shut down and the pc stays on.
if this is not the problem uninstall and reinstall the driver. the problem is between your pc and the printer or in the software.
May 18, 2010 | HP LaserJet 3600n Printer
Mfc7340 will not print--it was working just fine and then it errors out. Uninstalled and reinstalled and it shows ready but errors out
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
  1. Clear the printer queue
  2. Shut down the computer
  3. Unplug the USB cable from your computer and your printer
  4. Unplug the power cable from the printer and wait 15 seconds
  5. Plug the USB cable back into the printer and the computer.
  6. Plug the printer’s power cable back in.
  7. Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thank you,
Mar 26, 2010 | Brother Office Equipment & Supplies
Brother MFC-7340 Status monitor offline
Is it giving any errors when you try to print?
Sep 22, 2017 | Brother MFC 7420 All-In-One Laser Printer
We print to the printer through a windows driver but have to push go each time to print the page.
not required to press the go button . if the printer is in of line at that time you give print means you have to press the go button... to know the printer status.... if the ready light is on .. printer is online ... ready light off the printer is offline....... use correct printer driver for avoid junk print.....
Oct 15, 2009 | Kyocera Mita FS-1920 Laser Printer
Photosmart 2575 printer is offline - won't print
Hey jonboy - You do not want to delete it. It is automatically installed with Vista. In simple terms, you know when you go to print something and it asks you questions like print all pages, print page 1, etc? Well XPS basically is there for so when you go to print, you have the option of printing to a file instead of paper. You've always had that option ( whether or not you knew it) but this is just a new way of doing it and that's why it's listed under printers. It's sort of like a virtual printer. I'll say no more about that and just hope you understood what I said. As far as the other printer, it's already selected as default, go back in where you found the printer status, right click on your Photosmart and click on use online. That should do the trick.
I hope you understood this stuff. If this solves your problem PLEASE rate this as fixed. If you still have a problem, DON'T RATE it yet just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
Brother HL-2040 Laser Printer Logo
1,011 people viewed this question
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
