SOURCE: I receiver error number E000067-0110
The error indicates a high voltage problem with the primary or transfer units. The most likely cause is the main drum being worn out.
This can be checked by going into service mode. You can do this by pressing the star button once, then press 2 and 8 at the same time, then the star button again. Now a word of warning. Do not change anything as it is very easy to turn your copier into a cabage!!! Press the tab marked COPIER, then the one called DISPLAY, next the one called MISC. You will see an item called DRUM LIFE, if it is 80 or more the drum will need replacing. Hope this helps.
SOURCE: Vertical Red Lines
IS IT AN LCD ? IF SO IT MAYBE THE CONNECTOR ON THE LCD PANEL THET USUALLY GO DRY JOINTED
SOURCE: Can't launch a new game in Pirates Of The Carribean
your computer probably cant run the game, check your graphics card, RAM, and processor speed, make sure it meets the requirements for the game or exceeds them, if one is below, the game will most likely not work
SOURCE: Screen fliped upside down
Hi there.
Hold down Ctrl and Alt and use the cursor keys (arrow keys) to flip the screen the right way up, usually the cursor up key will do it.
Good luck and thanks for choosing FixYa!!
SOURCE: I get a burning smell when my car is in an idle
dear friend-the smell might be oil dripping from the tappet cover on to the exhaust,you will smell it when standing still moving creates a vacuum under the car which drags the smell downwards underneath the car.
