Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Kitchenaid Ultra Power Stand mixer manual or instruction how to oil.
Posted by rfrick753 on
Howard Lincoln
  • 235 Answers
Hi RFRICK753, There are no specific instructions to 'oil' your KA mixer. Your KA mixer's internal gears are factory packed with enough grease to last, with normal use, pretty much a lifetime. As grease will, over time, tend to break down, you may find the oil component of it seeping from openings beyond the gasket and "O"-ring down the agitator shaft. Gravity can be very insidious. But generally speaking if your mixer appears to be operating normally as it has in the past, you should not be overly concerned about 'oiling' it.
If, however, you feel it necessary to perform some TLC on your mixer, the good news is that the inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals& Guides> then enter the visitor type "Consumer" and enter the 6 character model number, in this case KSM90P, and select any file under Parts List (16); say KSM90PSAC0.pdf (354.08 KB) for example (all 16 manuals are exactly the same, but it's still wise to check and see if it matches your mixer, though).
Although not providing step by step instructions, the Parts List manual provides an exploded view of the various component assemblies allowing you to see how the mixer all fits together. It is helpful for the disassembly, troubleshooting, and reassembly of your mixer.
You'll find it quite messy 'under the hood' in the transmission box, but you'll be able to ascertain whether you really need to re-grease or not. Also, while your mixer's apart is an opportunity to check for any other unseemly wear and tear on the gears, etc.
After getting your hands this dirty, you may want to order a transmission gasket, an "O"-ring, along with some food-grade grease. Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping.
Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer. The mixers displayed in the links may be different than your KA model, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to peek under the hood and assess any maintenance needs for your mixer.
Posted on Jan 20, 2011
How do i change the brushes in my kitchenaid mixer?
Solution for these KitchenAid Stand Mixer Models
  • KitchenAid Stand Mixer Service Manual - K45SS
  • KitchenAid Stand Mixer Service Manual - K5SS
  • KitchenAid Stand Mixer Service Manual - KP50P
  • KitchenAid Stand Mixer Service Manual - KSM50P
  • KitchenAid Stand Mixer Service Manual - KPM5
  • KitchenAid Stand Mixer Service Manual - KPM50
  • KitchenAid Stand Mixer Service Manual - KSM75
  • KitchenAid Stand Mixer Service Manual - KSM90
  • KitchenAid Stand Mixer Service Manual - KSM103
  • KitchenAid Stand Mixer Service Manual - KSM110
  • KitchenAid Stand Mixer Service Manual - KSM150
  • KitchenAid Stand Mixer Service Manual - KSM151
  • KitchenAid Stand Mixer Service Manual - KSM156
  • KitchenAid Stand Mixer Service Manual - KSMC50
Fix KitchenAid Stand Mixer Workshop Service Repair Manual Download
Jun 18, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
I have oil leak from Kitchenaid standmixer, what should I do?
Where exactly is the oil leak coming from? Comment back to this post.
Apr 22, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Leaking oil from the mixer head. Occasionally find a drop of oil has collected on the end of the mixer shaft. What is the cause of this problem and can parts be ordered so I can fix it at home?
This is the end seal of the motor, you can get parts from manufacturer. you will need a service manual, OR go to the manufacturers web site and contact them.
Mar 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
LOOKING FOR RECIPE FOR MAKING BREAD DOUGH IN MY KITCHENAID KSM90 MIXER. I HAVE NEVER MADE BREAD IN MY MIXER, I DO NOT HAVE A MANUAL.
Hi Manfredi. Follow this link to download your mixer's manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Instructions%20and%20Recipes%20-%209704323.pdf
If this solution has assisted you, please rate it. Good luck, and don't overload the mixer when you're making bread dough. ricardok45
Mar 20, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid stand mixer is leaking alot of oil
ok, there are 4 skrews holding the body together on its white underside( or what ever color you have.) after you get those there are like 9 or 10 little skrews under a shiny rig that goes around the shaft that does all the work in the bowl. pull the ring off and take out those skrews. after that... well i have to find out for myself how to fix the oil leak! good luck and if you find out let me know! BTW here is a link to the service manual.
http://store.mendingshed.com/k45map.html
Oct 22, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
1,176 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
