Hello
Just check the left side speaker for its voice coil trouble. If voice coil has got damaged, this kind of fault will occure. If so replace the speaker with an identical one, both in size and impedence [ie resistsnce in Oms]. Connect an other good speaker of any type to the left speaker wire, and check whether the sound though it is perfect or not. If it is perfect, there is no doubt that the speaker inside the TV is damged. If the connected outside speaker also gives disorted sound, the Audio Output IC inside the Tv is faulty. Have to replace it with same type and number.
Before doing all these, go to the sound control section through your TVs menu options, and be sure that the balance control is set to mid position.
Ok.
all of the channel are resonding to the test. but you cant notice it bec 5.1 speakers, each channel are designed to respond to a certain frequecies. the L/R channel your talking about have the mid-range frequecies so it responds clearly compared to other channels...
hope that helps...
