Crankshaft Position Sensor
Engine speed is a very important input to the Engine Management System (EMS). Crankshaft speed and position are the basis for many calculations made by the computer. Crankshaft position values are transmitted to the computer by pickup coils also known as Permanent Magnet (P/M) generators, hall-effect sensors or optical sensors. The Crankshaft Position Sensor (CKP) also known as engine speed sensor is located in close proximity to the crankshaft.
In addition, the EMS uses minute variations in the CKP sensor data to determine engine misfire. The EMS uses this information in conjunction with the camshaft position sensor to perform misfire diagnostics.
Related Symptoms
No Start / Intermittent Start Condition - Can be caused by a faulty crankshaft position sensor due to loose connections, bad grounds, high resistance in the circuit, or opens in the circuit.
NOTE: For procedures on the position sensors, please refer to Driveability and Emissions.
Removal & Installation
To Remove:
To Install:
How to test Crankshaft Position CKP Sensor?
Crankshaft Position Sensor Operation?
Replace Camshaft position sensor and Crankshaft Position Sensor?
http://technoanswers.blogspot.in/2012/06/2005-dodge-durango-replace-camshaft.html
GMC Crankshaft Position (CKP) Sensor
Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-crankshaft-position-ckp-sensor.html
These details will help.
Thanks.
