Question about LG Heating & Cooling
I have got a problem with an lg inverter its a 24000btu/hr,the indoor is flashing six times and the outdoor unit is off,what can l do to make this unit run again?
Posted by elivious on
R Subramaniyam Iyer
  • 2,133 Answers
Inverter compressor run current high. Check compressor windings all equal 1 to 4 Ohms, Check to earth 50 MOhm minimum, check run current. If it's high, or windings open circuit, replace compressor.
Helpful?
Posted on Jan 20, 2011
I have a C6 error message on my LG LSZ244VT-5 AC Unit. How do I fix
LG Split System Air Conditioner Error code = C6 or CH06 LG AC Fault Definition = Excessive current at inverter DC power circuit - DC Peak Power
Flashing Light = 6
Display = Indoor Outdoor
Indoor Operation = SHUTDOWN
There are several things that can cause this,, first step is to check all wiring connections, but this can be pointing to a more major issue, the AC to DC transformer,,
It is a experienced tech kinda job
Jun 30, 2018 | LG Heating & Cooling
I have two flashes on the timer light of my indoor unit of Fujitsu Inverter ASU9RLS
Serial signal (reverse) error, at operation start up. operation led - off, timer led - 2 flashes, coil dry led - off, check wire between indoor and outdoor
Jul 10, 2015 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
36VDC Indoor split in a 240VAC country
if you use the correct inverter and transformers
best if you just get new units designed to run in that country
Jun 23, 2017 | Heating & Cooling
How to solve u4 alarm in daikin inverter 24000btu unit
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Feb 08, 2011 | Heating & Cooling
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Air con indoor unit is flashing 6 times out door is off
Please specify the make and model of your unit.
If this is a LG inverter model.
The six flashes of the indoor unit light indicates a CH 06 alarm.
This alarm state indicates that the indoor unit pipe temperature sensor has measured a temperature out of range or the unit is protecting itself from this low temp state. Indoor unit coil temperature to low. Should it have reached a temperature of -5°C for longer that 30sec it will switch the machine off.
It could indicate that the unit refrigerant charge is too low or the sensor has gone out of calibration.
It should measure 5kΩ @ 25°C
Mar 16, 2010 | LG Heating & Cooling
LG LS-Q09BUL INVERTER AIR CONDITIONER
This is possibly either a complete outdoor pc board error or an E-Prom error on the indoor pc board. You can try shutting down supply power completely for a minute and then switch on. These units also have a delay timer system which does not like to be switched on, off repeatedly in a short period. Please also check for reset button on the outdoor pc board. Hope this helps.
May 12, 2009 | LG Heating & Cooling
Heating & Cooling Logo
399 people viewed this question
Top LG Heating & Cooling Experts
Marvin
Marvin
Steve Oakes
Steve Oakes
Muntejaya Ginting
Muntejaya Ginting
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
