Question about Plumbing
I have Belanger taps all over the house and there is not much hot water coming out of my belanger shower taps(2 bathrooms), tech said I need to change the cartridge, would this fix the problem? All of the other taps are working. I have replaced my kitchen cartridge, but that was because it was leaking. Please help. Thanks.
Posted by bearcatmom22 on
  • Hannah Schroeder
    Hannah Schroeder Nov 23, 2017
    It's weird that there's no water coming out of taps from the same brand even though they're in 2 separate bathrooms. I'm having a similar problem, except my shower heads are different brands, and there's water coming out of the sink. Maybe we should both hire a plumber to see if they can find out what's going on. http://www.rooterproplumbing.com/ca-plum...
Bill Boyd
    Top Expert:
  • 53,814 Answers
The only thing to do is to replace what was suggested and see if that improves the situation if you still have the old leaking one , that would be good enough to prove a point
Posted on Nov 23, 2017
1 Related Answer
Mike
  • 4369 Answers
SOURCE: I have a single
Check the hot water shut off valve, when the washer fails sometimes the valve itself sticks closed, and sometimes the washer breaks up and clogs water passageways down stream...
To test, pull the hose off of the hot water shut off valve, open the valve and see if you have water flow. (route hose into a bucket, you need more that a small amount of water.....
If you have good water flow from the shut off valve, then you likely have a particle that has lodged in the passageways of the faucet. Reverse flow with air pressure and see what you get out....
Posted on Jul 17, 2011
My shower only stays hot for a minute and then goes cold even though the hot water works everywhere else. I have a hot and cold tap and a third one to direct to shower or tub.
I would take a look at the stem replacement task. Maybe something is clogging the hot water flow, perhaps a damaged washer or debris
Jan 14, 2013 | Moen Home
Kitchen taps belanger leaking need to know how to get the top apart
A definitely beneficial submit by you my buddy. We have bookmarked this web page and can appear again following several days to verify for virtually any new posts that you simply make and also you will see it Kitchen Taps
Jan 01, 2013 | Plumbing
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
I have a single handle belanger shower faucet- replaced cartridge and no hot water , Need help
Jul 17, 2011 | Plumbing
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
Remove belanger one handles shower faucet cartrige . I took off the little colouted rubber plug but I cannot seeinside to remove the small screw to get at it. Can't even see what kind of screwdiver that it...
Please contact Bélanger Customer Service at 1-800-361-5960 with your product number or view our website at www.belanger-upt.com to find your model number.
Nov 07, 2009 | Plumbing
I have hot water coming out of house taps but not from out of the shower, we do not have a bath tub. there seems to be no obvious leaks. HELP! what can i do i have 4 stinky kids that badly need a shower
The tap fitting on the shower may have failed. Some of the modern fittings have a more complicated internal mechanism than the traditional taps and can fail rendering the tap inoperable. Turn off the water at the mains. First take off the tap handle and then with a spanner carefully unwind the tap spindle. Be very carefull not to use excessive force in case you damage the pipework behind. If it does not come ralatively easily leave it for someone else. When you have this out have someone crack the main valve and you should have hot water coming out. If the fitting itself is the problem you may be able to take the spindle and washer out of a standard brass garden tap and use it as a temporary fix untill you get a propper replacement. Just another thought, you may have an isolation valve on the hot water line to the bathroom. Could a kid have turned it off?
Aug 30, 2009 | Rheem Tankless Hot Water Heater...
Shower problem
This must be a joke because there is no way the shower is connected to your faucet. the faucet on you vanity is connected directly to your hot and cold water supply. And only by opening the hot water side of the faucet can you get any hot water.out of the faucet.
Aug 01, 2009 | Home
No cold water from bathroom tap
Sounds like you need to replace your shower valve, especially if this is the only fixture in the house being affected. You could try to replace the cold water cartridge first. Hope this helps
Jul 06, 2009 | American Terminal Etc B 100 T Taps
Plumbing Logo
587 people viewed this question
Top Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
