Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
Posted on Feb 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung LE32R7 3BD LCD will be watching TV for about fews hours and all of a sudden the picture will go funny lines will appear. I switch the TV off unplung from the main, wait a few min and then put the TV back on again and it working fine, and a couple of hours later it will do it again.
Lawrence Oravetz
Level 3:
  • Samsung Master 10,558 Answers
  • Posted on Feb 14, 2018
Lawrence Oravetz
Samsung Master
Level 3:
Answers
10558
Questions
Helped
2699798
Points
29284
Sounds like the T-Con board is going bad; You can get replacements here : TV Parts Universal TV Stands DLP Chips ShopJimmy
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Jan 28, 2009
SOURCE: Samsung LN-S4041DX 40 in LCD TV
Hi. You can try to go into service mode and reset the LCDTV to Factory Default. This will clear out all buffer over run's and any software related issues. It may fix the problem or it may not. If this doesnt fix the problem than you need to have a qualified Technician to look at it. The problem is in the AV circuit board, a technician who is qualified to repair electronics at circuit board level should be able to repair this problem rather quickly and inexpensively. Most technicians who do not have the expertise in repairing cicuit boards to component level would rather replace the whole AV board than repair it and this will be rather expensive.So talk to the repair shop before you drop the TV off.
Be very careful when accessing service mode. I suggest to write down all information in all areas before proceeding to a factory reset. If you do not record all values correclty you run the chance of not being able to use the TV again. To go into Factory Service mode, use the original remote and in this sequence push POWER OFF-MUTE-1-8-2-Power ON, the set will turn on and enter service mode, if you hit all previous keys correctly. If it doesnt try again. When you are done hit POWER OFF and this will exit service mode and save the data.
Anonymous
  • Posted on Mar 03, 2009
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Anonymous
  • 304 Answers
  • Posted on Jul 16, 2009
SOURCE: 46" Samsung LCD, no sound output whatsoever
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
Anonymous
  • Posted on Nov 19, 2009
SOURCE: Samsung LE40B550 - No Picture
I had exactly the same problem with my LE40B550 which I bought in July. I phoned the place I bought it online (eBuyer) and they put me in contact with a Samsung repair centre who fixed it under warranty. It took them 2½ weeks to fix it and get it back to me. The note that came back with the TV said they had replaced the IP board. I think the part number was H40F1 9HS.
The repair centre paid less than £50 for the board (it shows on the returns paperwork).
If you only bought yours in August, and haven't had it fixed yet, I suggest you just get in contact with whoever you bought it from and get it done under warranty.
Chi Chu
  • 8457 Answers
  • Posted on May 01, 2010
SOURCE: HDMI input is not working.
That HDMI port hub,it shorted.It have intermittent problems,it will work sometimes,sometimes not,best just skip that HDMI port hub.I know i have a samsung LCD tv it have 6 HDMI ports hubs,3 AV RCA cables input functions,and a S-Video input cable port.That plenty,so don't care about that HDMI port hub.
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
5helpful
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
2answers
Samsung 40 no picture
If it is only 6 months old you probably still have a warranty. This is definitely a hardware issue, and unless you are comfortable taking your new TV apart, I would contact Samsung for repair.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
