Question about Kenmore 4292x Front Load Washer
SOURCE: kenmore elite HE3t
Unplug your machine, remove the top panel, doublecheck all of the wires are securely connected. Sometimes the wires are loosened due to the vibration of the washer. Hope this works for you! It worked for our Kenmore Elite H3 when no cycles would start and flashed the error code "dL/F" (door lock failure).
Posted on Jan 02, 2008
SOURCE: How Do I replace the
Here ya go, click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the instructions thoroughly before starting. This is a fairly straight forward and simple repair job. If you require further assistance, go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
Posted on Jun 16, 2008
SOURCE: Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Posted on Oct 02, 2008
SOURCE: keep getting f2 signal on
F2 and F02 error are one and the same.
My daughter was doing a load of towels in my Kenmore Elite HE3t front loading machine, when I went back to put them in the dryer the washer had a load of water in it and an error reading of F02. Checked the manual Could not find anything wrong with the Drain Hose?
These are the possibilities for that error code at one web site:
Press PAUSE/CANCEL twice to clear the display.* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
F02 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F02 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
Posted on May 06, 2009
SOURCE: F11 & FDL error codes several times per load.
HI. this is a door lock error code.
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.((Which will be a failed door lock assembly in this case))
Posted on Aug 31, 2009
Testimonial: "Thank you for your response. This is a year long battle. Now, we're up and running again!"
Mar 24, 2015 | Kenmore HE3t 4.0 cu. ft. Front-Load King...
Oct 30, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
Apr 01, 2013 | Kenmore Washing Machines
Apr 12, 2010 | Kenmore Elite 45986 Front Load Washer
Jul 01, 2009 | Washing Machines
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
Aug 21, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Jun 20, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Feb 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
