You've accidentally turned on "repeat" or "repeat 1" mode. If it has a "mode" key then press it until you cycle through "repeat all" and/or "shuffle" and/or "shuffle repeat" until it says nothing. If you have a cheaper player, the "play mode" function may be hidden in a menu somewhere, to save the physical button. Check around in the menu/settings to see if you can find it, or, in the last resort, check the manual.
SOURCE: MP3 Player plays only 25 songs, capacity 1GB (861 MB)
Seems like a big problems you got there...
I reccomened re-formatting your drive to fat32 (for windows users) and giving it a second try.
I had the saem trouble a while back with my iPod Video 60gb and noticed that it was storing huge amounts of data that wasnt meant to be there. After the reformat it all worked again.
You also sure its not a full drive? because my Q-Be used to say "file error" on a full drive (vista bug)
---Give reformatting a go though.
SOURCE: Electro brand mp3 player(model mp3774) only plays 10 secs of song
I have the same 3774 mp3, what I did was took a nother mp38379 that worked, I download all the info to a dir in my labtop, then I put the mp3774 in and formated, then I uploaded the info from my mp338379 to the mp33774, the format is wma from mpe338379 is [wma] and the mp33774 came to file it now works
SOURCE: my uncles mp3 only plays 10 seconds of a song each time it plays
Your Uncle's player is stuck in INTRO mode. To remedy this problem
1. Play a song
2. press the button on the side of the player
3. Select PLAY MODE
4. Choose NORMAL
