Question about Sony DVP-NC85H Multi-disc DVD Player
My dvd drive is not take any disk but it is opened and close & its read light is blink & a sound is heard why
Bruce lee
    Genius:
  • 1,637 Answers
SONY EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Posted on Jan 19, 2011
Well.. i can close my disk drive all i want, however, it will just keeep on opening and closing and wont read the disks at all and i cant afford a new one... my xbox is under 1 year of age. i got...
When the xbox is blinking it means 2 things. the cable that connects to your drive needs to be replaced or your DVD no longer works. The connector cost around $3 or a New Drive cost around $30 on ebay
Thanks
www.1RepairStop.com
Aug 30, 2011 | Microsoft Xbox 360 Console
We can not start any video games or movies,... we heard sound in the console,....like it is trying to read them but then in the main screen say open tray , like there are not disk in it. could you help us...
Your disk drive is going bad when it won't read any cd's, dvd's, or games it keeps saying open tray. There are different types of disk drives also, to determine yours go to llamma.com/xbox360/Xbox_360_ DVD_Comparison.htm (new disk drives normally range between $40-60) and if you choose to repair it yourself you'll need a small flathead & philips head screwdriver and a very small torq bit set to remove internal screws. It takes about 20 minutes if you know what your doing and youtube has a number of videos to walk you through it if you need them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Which dvd disks do I buy to burn a dvd on my optiarc dvd rw ad 7563a ATA Can I add later batches of pictures? can I reuse the DVD disks?
DVD media has several types:
* DVD-R ("write-once-read-many")
* DVD+R ("write-once-read-many")
* DVD-RW ("write/erase/rewritable")
* DVD+RW ("write/erase/rewritable")
* DVD dual-layer ("write-once-read-many")
Some CD/DVD-writing software allows multiple "sessions" (write a bunch of files, do not "close" the disk, much later write a bunch of files), so that you can "add" files to an "open" ("non-closed") CD/DVD disk.
Jan 24, 2010 | Gateway (5500652) (  5500652)...
How to convert dvd +r to dvd -r
Use DVD Shrink & Nero Burning Rom
1. Put the DVD +R in your computer's DVD burner drive
2. Open DVD Shrink
3. With 'Full Disc' checked, click 'Open Disc' button.
4. Choose settings as required.
5. After it does the quick preview, click 'Backup'
6. When it prompts you to insert a DVD insert a DVD-R
7. Close the dvd DVD drive.
8. When done, enjoy the movie.
Sep 27, 2009 | Panasonic DMR-EH60 DVD Recorder/HDD...
Can't read discs
Is power getting to the drive? Will the tray open and light blink when closing the drive?
If so, it sounds like the lens may be dirty. There are several things you can try: Gently blow into the open drive, use a vacuum, purchase a lens cleaner.
Sep 06, 2009 | Toshiba Satellite A135-S2386 Notebook
The power light blinks, reads open tray/close tray . . .
it sounds like your dvd drive is dead if its still under warranty you should just send it back to microsoft the only other thing you could do is buy a replacement dvd drive and put it in yourself but only do that if microsoft wont take it or you'll void your warranty
Aug 25, 2009 | Microsoft Xbox 360 Console
Blinking green light/won't detect disk drive
the sata cable sliped from the dvd drive (if under warranty send it back) if not open yourself and plug it back it
May 22, 2009 | Microsoft Xbox 360 Pro System Console
Xbox 360
You will need your dvd drive replaced. We can do this for you.
www.videogamerepairservice.com
Dec 30, 2008 | Microsoft Xbox 360 Console
CD drine issue
To manually open the CD Drive, straighten a paper clip and insert it into a tiny hole in the front of your CD drive and push the paper clip gently into the drive and the tray should then pop open.
Open and close this several times, then insert a disc into the drive and see if it will read the disc.
If not the drive is dead and needs to be replaced.
Nov 18, 2008 | Acer (KV.16X04.007) DVD Drive
Sony DVP-NC85H Multi-disc DVD Player Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
