Question about Biostar GF7100P-M7S Motherboard - v6.0, NVIDIA GeForce 7100, Socket 775, MicroATX, Audio, Video, DVI
My motherboard Biostar GF7100P need to program bios ,\r\nmy motherboard only turn on but do not action ( no picture in screen , no beep in motherboard ) my pci post code card show "FF" code in segment.
Posted by microvbavr on
Byron Narciso
    Guru:
  • 679 Answers
The first thing that I would do is check the MoBo's website and find a RAM compatibilty chart. Make sure that you Mobo doesnt have any know issues with your particular RAM. You may also check the RAM's website and look for compatible RAM for your MOBO. Rule this out first. The Sata F6 thing depends on the MOBO I think that most of the time you do have to f6 the drivers however on my ASUS this was not necsessay. My cut at this would be to take everything out of your system except for the few components that it requires to boot up and load the OS. RAM, Video Card, CD ROM, maybe the Floppy. Reformat your HD so that you can start over clean. Make sure that you have each cable plugged into the mobo correctly as well as the component. Reformat, then reload the OS. Start to load the system drivers one at the time rebooting after each is loaded. Pay attention to what you did last if the problem shows up again. This will probably point you to the issue. If every thing installs correctly without any problems then start putting the other hardware in one piece at the time loading the drivers andsoftware for each component then rebooting and ruung some stress test before moving to the next component.
Posted on Jan 19, 2011
Biostar gf7100p-m7s hard drive not working
I would flash the BIOS, sounds like something is corrupted, if that doesn't work then the blame has to be the HDD, you need to try booting with a different one, maybe a PATA too see if your problem goes away or changes. Any PATA will do, this is only a test.
http://www.biostar.com.tw/app/en-us/mb/bios.php?S_ID=348
Another SATA would even be better. Good luck.
Jul 15, 2009 | Computers & Internet
Hi-low beeps at boot. System won't even get to BIOS.
That is probably your ram. If you have more then 1 stick remove them and install one at a time in slot 1. If that isn't it you need to count the beep and duration of the beeps. I can then look up the codes. I will also need to know your bios manufacture.
Jul 09, 2009 | Biostar M7VIT Motherboard
Biostar gf7100 mp - wont boot with ext usb drive attached
Hi, What you have to do is shut down the machine, pull the CMOS battery(CR2032) out and out and put your jumper on pins 1-2 from 2-3. Wait 30 seconds and put the battery back in. After installing the battery, put your jumper back to pins 2-3 from 1-2. This should work.
Jul 07, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Sound doesn't work on biostar gf7100p-m7s
it's a common problem of gf7100p-m7s series. Its depend on ur operating system. beoz many operating systems have their own audio drivers like windows vista. If u r using windows vista don't install audio drivers from ur motherboard disk. becoz i had faced this problem some months ago. if this is not hardware relative problem, u can see ur sound will work fine.
May 28, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
No video display
hello mr,carrera :) ...
i think u have only two choices u have to do :
1: you disconnect the power cable from you PSU , then reset the BIOS using the jumper pre-installed on your board , check the manual for this " Clear CMOS " ,,
then try again , if not then
2: u will have to replace your bios with an updated one of the exact motherboard model , you can do this easily cause Biostar have the socket of Bios ,not mounted in the motherboard ,,,
so, i am pretty sure that its a bios issue , like 95% ,,,,
the 5% u don't wanna know it ,,,,( Bad PSU might affected the power ct. of your Board :( ,,,, but try Bios 1st....
May 15, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Connect cd drive to biostar gf7100p-m7s
The 34 pin connector is for your floppy drive(s) .. not for your CD drive. There is no special cable for this. 2 different interfaces alltogether.
Feb 17, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
On first power up, no video, no sound.
hi
*********** board dead
hope ur smps &ram also ok ......
pl z check motherboard near pc service care.......
Jan 12, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Biostar GF7100P-M7S Motherboard - v6.0, NVIDIA GeForce 7100, Socket 775, MicroATX, Audio, Video, DVI Logo
77 people viewed this question
Top Biostar Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Davit Mamyan
Davit Mamyan
Roy May
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
