I assume you are using windows. Follow these steps to adjust the screens brightness:
- Go to the Control Panel
- Go to display
- On the left pane click adjust screen brightness
- At the bottom of the screen you should see the screen brightness meter being displayed. Change it accordingly and then apply the settings to keep them.
Alternatively you should be able to adjust the brightness of your screen using the a combination of keys on your keyboard. This differs with the type of machine though
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
These are the Function keys
<Fn> + <↑> Volume up Increases the sound volume.
<Fn> + <↓> Volume down Decreases the sound volume.
<Fn> + <→> Brightness up Increases the screen brightness.
<Fn> + <←> Brightness down Decreases the screen brightness.
